Hi all ,
Just got my friend into virtual dj but he has pretty poor eyesight , is there a skin that anyone of you have come across with larger writing to help him find the tracks easily . Any responses would be greatly appreciated.
Best Regards
Best Regards
geposted Thu 22 Dec 11 @ 10:13 am
Check out some of the newer skins in the download section, they have a text size selecter built in.
Keith
Keith
geposted Thu 22 Dec 11 @ 10:45 am
If he is going to use an older skin just follow this video I made, it's over 4 years old now but the principle is still the same....
There is another tutorial covering fonts specifically if you need to check it out in my blog.
If you still have problems I can talk you through it on Skype if you want.
geposted Thu 22 Dec 11 @ 12:28 pm
Many thanks for your replies , I am now very busy over the xmas period but will certainly have a look at what you have posted.. Thanks a lot...
geposted Fri 23 Dec 11 @ 3:19 am
Hi kradcliffe,
Can you please let me know which skin you can change i have checked a few of them with no luck , also in the skin where is the bit where you can change the size of lettering ,
Many thanks in advance
geposted Fri 23 Dec 11 @ 3:33 am
I'm on my mobile at the mo but will have a look when I get home and let you know. What's your maximum screen resolution?
Keith
Keith
geposted Fri 23 Dec 11 @ 3:40 am
Hi All ,
Thanks but just managed to change the font size using the tutorial , it works a treat , he will be well happy this weekend ,
Thanks again to your replies. It just shows it does pay to talk !
Merry Christmas
Merry Christmas
geposted Fri 23 Dec 11 @ 3:44 am
Here are the skins I have made and you can change the text size:
1440x900:
1920x1080:
Also djdad has made several skins with this ability ;)
1440x900:
1920x1080:
geposted Fri 23 Dec 11 @ 4:22 am
@playcock... Your welcome, glad I could help.
Merry christmas.
Merry christmas.
geposted Fri 23 Dec 11 @ 4:29 am
Thanks for doing this Video, I went straight to the browser section and changed the font to something that I can actually see without looking for my glasses first!
Excellent bit of information.
I just copied, altered & resaved the file as the xml then renamed the XML file and the bitmap image to be the same name.
Opened it up in Virtual DJ and there it was with the font changes.
Thanks again.
Thanks again.
geposted Fri 09 Mar 12 @ 7:29 am
Thank you for taking the time to mention the tutorial.
geposted Fri 09 Mar 12 @ 8:37 am
i did this ages ago, thanks to tayla
geposted Sat 10 Mar 12 @ 9:10 am
geposted Sat 10 Mar 12 @ 9:19 am
Did anyone mention there is a button at the bottom of the screen/browser to INCREASE/DECREASE text size?
geposted Sat 10 Mar 12 @ 12:12 pm
Unfortunately that option is not available on all skins, hopefully it will be there in the next release.
geposted Sat 10 Mar 12 @ 12:23 pm
Paul i just tried those changes you implement in your tutorial (size 18 , yellow, transparent, etc)
and it didn't work on the default VDJ 7 2 deck skin (1280*768 xml) in win7 64 bit
i had that working before u probably remember on Vista 64 bit......
is it unavailable in win 7 or VDJ7 ??
geposted Sat 10 Mar 12 @ 3:51 pm
I played with this 1 and got it just right for ME @ night......
geposted Sat 10 Mar 12 @ 6:36 pm
geposted Thu 07 Jun 12 @ 4:16 pm
