I bought a pioneer ddj ergo,Been VirtualDJ LE,But I want to upgrade to VirtualDJ Pro Full,Now I want to know is whether the interface will change after the upgrade,I like to customize the interface now ddj ergo, so I want to ask, thank you
geposted Fri 06 Jan 12 @ 4:01 am
I'm afraid not.
The skin (interface) provided in the VDJ LE that came with DDJ Ergo is specially made for that LE version you have.
Kindly check this out:
http://it.virtualdj.com/forums/157286/VirtualDJ_Skins/Skin_from_DDJ_ERGO-V_-.html
geposted Fri 06 Jan 12 @ 7:15 am
Once you have upgraded your VDJ LE/HOME to VDJ Pro you will have all the benefits like downloading plugins effects, skins, video effects and mappers for your DDJ ERGO.
geposted Sat 07 Jan 12 @ 3:52 pm
Hi There
If I do not wish to upgrade from LE to ProFull version, does this means that I will not be able to use the equipment with all the features off the box? I intend to get the Stanton DJC4. What are the limitation and miss out if I only choose to use the LE version provided.
Thanks
Thanks
geposted Thu 06 Sep 12 @ 9:51 pm
