Forum: Wishes and new features
Topic: About an A->B loop control??
FruitPRO InfinityMember since 2003
Mixvibes provides this feature. Could you make the beatlock feature locks the loop length (and not beats) on the other deck's tempo, it might make infinite possibilities of loops, and mix a 3beat tempo or a 7beat tempo to fit a 4/4melody in other deck.
Excuse me i'm french is that clear?
I really enjoy VDJ. I hope this feature will happen. I wait for a filter too. Greats!
geposted Thu 04 Sep 03 @ 1:05 am
nscodeHome userMember since 2003
Yeah... I like what you're saying. And I want a filter too! Filter is the only reason I use DSS DJ more than VDJ.
geposted Thu 04 Sep 03 @ 8:16 am
The A to B loop feature allows to make 'very special' tempos, and really offers an infinite possibility of loops. But the beatlock feature would have to be updated to correspond with loops obtained.
I think the filter feature is a very important think, allowing you to make small effects to sounds. Maybe a plugin could be wrote to allow it? I dont't know...
For the teamers : could you answer this and explain if it's possible to do. This two features are really missing in this great soft. If it is added, Traktor would be far from Virtual DJ, very far...
geposted Thu 04 Sep 03 @ 1:28 pm
Dev staffHome userSenior staffMember since 2003
The manual loop feature already exists, but it is not available on the default skin.
You should either download a skin that presents this feature, or define some new shortcuts (the action to use are "loop_in" and "loop_out")
geposted Thu 04 Sep 03 @ 7:53 pm
You say I can create buttons with this sortcuts commands??
I'm going to try this right now! Thanks for this helpfull advice. If you're right the filter is the only thing to add. So Virtual DJ would be PERFECT!!?
geposted Fri 05 Sep 03 @ 3:46 am
I added logos to my submitted skin but...
geposted Fri 05 Sep 03 @ 3:47 am
I guess it doesn't work on the 1.02 version? Can you explain it, please?
geposted Fri 05 Sep 03 @ 4:07 am
OyyoDamsPRO InfinityHonorary memberMember since 2003
Why do you still use the 1.02 version ?
geposted Fri 05 Sep 03 @ 11:50 am
Yes I was stupid to ask but I saw that late...
Thanks for your helpfull advices.
geposted Fri 05 Sep 03 @ 1:17 pm
Can I create a button to exit the loop. I didn't find the action name. Can you tell me please? Thanks.
geposted Tue 09 Sep 03 @ 1:04 pm
kaleoPRO InfinityMember since 2003
create a shortcut "loop" with: value="0"
geposted Tue 09 Sep 03 @ 1:36 pm
DJ RickPRO InfinityMember since 2003
the latest silver skin posted by Jim Nordic has buttons on the skin for loop in and loop out.
geposted Tue 09 Sep 03 @ 5:13 pm
Thanks for your "veryfast" aswers. I wanted to know if a BUTTON can be created to exit the loop, that I can include in a xml. Or only the shortcut exists?
geposted Tue 09 Sep 03 @ 9:34 pm
As you can do a shortcut, you can create a button on a skin.
In the xml file, choose the action "loop" and the value=0.
Easy, isn't it?
geposted Tue 09 Sep 03 @ 9:39 pm
Sooo easy, too easy, I didn't expect that. Thanks.
geposted Wed 10 Sep 03 @ 1:43 pm
