What virtual DJ software is compatible with the Numark NS6 ???
geposted Mon 26 Mar 12 @ 9:07 pm
Guys, im new to this whole new VDJ thing.....any help/advice would be appreciated.
geposted Mon 26 Mar 12 @ 9:14 pm
Virtual DJ is working very good with NS6 - love it
geposted Mon 26 Mar 12 @ 9:30 pm
You have to use VirtualDJ PRO FULL in order to have controller support - http://www.virtualdj.com/buy/index.html
geposted Mon 26 Mar 12 @ 9:44 pm
In relation to the NS6, I was playing with it at Guitar Center over the weekend. Guitar Center had it hooked up with Serato Itch. When I triggered the FX, I noticed that the sound was very tinny (not sure how else to describe it). The effects did not sound like normal effects, they really sounded computer generated. When using the NS6 with VDJ, does it use the VDJ effects processors or processors in the NS6? I use lots of effects when I mix (LPF, HPF, delay, etc) and am very happy with VDJ's effects processor and want to make sure if I invest the money in an NS6 I will not lose any of VDJ's functionality. Thanks for any help.
geposted Mon 26 Mar 12 @ 10:29 pm
Works great with virtual dj pro, effects sound normal to me.
geposted Mon 26 Mar 12 @ 11:00 pm
I do have some issue with the effects. I use to use the Echo V2 effect a lot and now with the NS6 it does sound weird. I haven't really tried it with the other effects so I can't say for sure if those are different as well.
geposted Tue 27 Mar 12 @ 9:58 am
The NS6 does not have built in effects - it will always use the software's effects. So, Yes - you will still be able to use hat you are already use to.
geposted Tue 27 Mar 12 @ 2:28 pm
VDJ 7.05 works well with the NS6. All buttons works. Can't speak for the effects as I rarely use them. Maybe just a Flange here and there, and that works great.
geposted Tue 27 Mar 12 @ 2:35 pm
I recently purchased VDJ Pro... I cant get my headphones to work with my NS6. Also, effects button on my NS6 not working like it should either.... Am i doing something wrong ????
Any help ??
Any help ??
geposted Wed 28 Mar 12 @ 8:35 pm
Am i supposed to do anything before I start using it with my NS6 ???
geposted Wed 28 Mar 12 @ 9:11 pm
Please register your Pro serial number on the page http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html
Once you have done this, please see the controller configuration FAQ page about this controller:
http://www.virtualdj.com/wiki/NS6.html
geposted Thu 29 Mar 12 @ 5:51 pm
Everyone,
Thanks for the input!
Kwik
Kwik
geposted Thu 29 Mar 12 @ 10:12 pm
i have a dumb question ? i love my NS7 but its just getting 2 darn heavy 2 lug around by myself. so ive been looking into buying the NS6 (BUT) i see alot of complaints on the serato user forums about if your only using 2decks you can hide the other 2 not being used. there 4 having wasted space. so my question iz will all that not be a problem with VDJ ? thanx sorry if my question iz confusing.
geposted Sat 31 Mar 12 @ 12:35 pm
No, this would not be a problem since you can select the skin you want to use be it a 2 deck or 4 deck skin. I did notice the 4 decks on itch but to be honest with you it never bothered me. I guess it would bother me if I had a smaller screen on my laptop.
geposted Sun 01 Apr 12 @ 11:53 am
How hard is it to go from itch to Virtual DJ (pro) on the NS6? I love the simplicity of Virtual Dj and want to use it instead of Itch...
geposted Sat 16 Jun 12 @ 12:51 pm
I cant control the effects using my NS6 and when i try to video mix it keeps hanging after 2 seconds of play then plays for 2 seconds. Are there video setting an supposed to set. help please. am just new to this software..
geposted Sun 17 Jun 12 @ 1:19 am
You should register your serial number and check for updates on your version first.
Greets, Heiko
Greets, Heiko
geposted Sun 17 Jun 12 @ 5:18 am
Greets, Heiko
Greets, Heiko
geposted Sun 17 Jun 12 @ 12:29 pm
Ok i have already registered. Now assist on how to use video mix and how to record a video. Hope am not gonna be forced to buy another video convert software
geposted Sun 17 Jun 12 @ 12:31 pm
