Hi all,
Now available for download is my new scheduler plugin. It allows you to specify preset times to execute VDJScript commands. It also implements a function to allow you to load a playlist at a preset time too (VDJScript doesn't currently have this).
It installs a PDF instruction file in your Documents\VirtualDJ folder which details the schedule file format.
http://www.virtualdj.com/addons/14681/SBDJ_Scheduler.html
Regards,
Scott
Regards,
Scott
geposted Wed 25 Apr 12 @ 7:11 pm
v1.01 has been released:
* Fixes an issue whereby duplicate events may be created when the schedule is reloaded. All users are advised to update ASAP.
* Adds Mac support.
Mac users will need to copy the bundle file into Documents/VirtualDJ/Others. The zip file includes the PDF documentation.
* Adds Mac support.
geposted Thu 26 Apr 12 @ 2:10 pm
You currently saves Schedule.xml in
C:\Users\{username}\Documents\VirtualDJ
why not in:
C:\Users\{username}\Documents\VirtualDJ\Plugins\Other ?
geposted Thu 26 Apr 12 @ 2:48 pm
I was just trying to put it in easier to access location.
I have no objection to putting it there though.
geposted Thu 26 Apr 12 @ 2:57 pm
Does this work with VDJ8? I can't seem to find it under the effects, although they are now deck-specific.
geposted Thu 04 Sep 14 @ 12:14 pm
