Forum: VirtualDJ Plugins
Topic: [UPDATE] Effect Slipmode V2.0
ChacklPRO InfinityMember since 2007
Hello!
I've now finished the next Version of the Slip-Mode Effect!
http://www.virtualdj.com/addons/15215/Slipmode_-_Scratch.html
Question to Mods
Could somebody please be so kind and rename the Effekt to "Slipmode" and not "Slipmode-Scratch"? - Thanks!
New changes in Version 2:
* Support of Loops and Reverses
* Added Manual Trigger for Slip in VDJ-Script (for egsample with an other effect) - See Variable SDK
* No Multideck Problem anymore - working on 99 Decks at same time!
Variable SDK:
VDJ Script variables for input from VDJ:
manual_slip 1 - Start the Slip-Counter. Song will continue in background.
manual_slip 0 - Performs the slip to the position of the Song in the background.
VDJ Script variables for output back to VDJ:
is_slip - Shows you if you are sliping or not.
Have some fun!
Regards, C.Hackl
geposted Mon 08 Oct 12 @ 2:52 pm
Update 2.1:
Added support for Jog-Wheels and Skin-Scratch with a fix in the scratchdetection.
If you have a jog without touch or want to scratch on skin - switch on the "Touch Emulation".
Best regards, C.Hackl
geposted Wed 10 Oct 12 @ 5:44 am
Cool! Good effort!
geposted Wed 10 Oct 12 @ 10:31 pm
geposted Fri 12 Oct 12 @ 10:54 am
dydy1PRO InfinityMember since 2006
geposted Sat 13 Oct 12 @ 12:49 pm
yes! just activet the effect and then scratch, Loop or reverse the song. everytime you scratch/Loop/reverse the slip will be performed. ;)
Regards
geposted Sun 14 Oct 12 @ 5:49 am
best plugin EVER!
Thanks chackl :-D
geposted Sun 14 Oct 12 @ 8:27 am
synthet1c wrote :
best plugin EVER!
Thank you! Nice to see that you like it ;)
geposted Sun 14 Oct 12 @ 9:46 am
When I activate the effect on my two Denon DN-S1200s and try to scratch the music simply stops, but the touch sensitive Jog wheels refuse to scratch. When I deactivate the slip mode effect the music scratch normally.
geposted Sun 14 Oct 12 @ 11:28 am
what is your mapping Action on the touchwheel and touchwheel_touch?
geposted Sun 14 Oct 12 @ 2:04 pm
I use that script for Jog= deck active effect active ? device_side 'left' ? deck active effect slider 1 : deck active effect slider 2 : touchwheel. I use my jog to control effect slider 1 and 2 qhen effects are on.
and I use this script for Touchwheel= touchwheel_touch
Akso when the slip mode effect is active I still want the needle arm to still show its true position on the LCD of the Denon DN-S1200.
geposted Sun 14 Oct 12 @ 5:56 pm
well, after a "goto" the needlearm is reset to 0 again. since now i did not get another solution for that :/
Well if you enable the touchwheel and the touchwheel_touch it should work fine. Otherwise try to switch on "emulate Touch". mabe it works better then.
Regards
geposted Mon 15 Oct 12 @ 1:28 am
djcelPRO InfinityModeratorMember since 2004
Chackl wrote :
Question to Mods
done
geposted Mon 15 Oct 12 @ 4:52 pm
djcel wrote :
Chackl wrote :
Question to Mods
done
Thank you verry much!
geposted Tue 16 Oct 12 @ 2:16 am
MistouLE userMember since 2013
Sorry I am a mac user, and I failed installing the slipmode plug in, can you help me please
geposted Thu 17 Jan 13 @ 10:07 am
what Version of virtual DJ do you want to use with slipmode?
geposted Sat 19 Jan 13 @ 8:44 am
djsadimPRO InfinityMember since 2006
hi!! I have downloaded the latest version. do not work VDJ Script variavles
this is strange shows up version 2.2 and not 2.2.1
geposted Tue 29 Jan 13 @ 4:25 pm
i did not edit the version number lat time, sorry for that ;)
Regards
geposted Mon 04 Feb 13 @ 1:25 am
geposted Tue 05 Feb 13 @ 4:51 am
