Topic: 2013 Atlantic City DJ Expo - Page: 3
no videos yet?
Yes, nice, but the basic question: is VDJ 8 finally out there, or still not?
This is not a thread about v8. Please keep on topic.
My question is . is v8 on display at the expo?
It means not?
(It is on topic. It is about DJ Expo, and some older main versions of the VirtualDJ (VDJ 4, VDJ 5) were released there too.)
Yes Sir. Version 8 with the latest skin debuting the new "SandBox" feature is on the show floor for all to get their hands on. It's running on 5 of the 8 floor demo setups. More info coming soon.
<image removed>
ahhhhh...mouth Watering....
whats in the box....w-h-a-t-s in the b-o-x...what is the sandbox feature
Sand ??
**hihi**
One word ? ... It's M a g i c
Once you activate it, nothing will interrupt or affect the master output.
The track will keep playing as normal for your audience but physically you can do whatever you like using your controller (or the mouse/keyboard).
It is like you are moved on a cloned computer with the exact same setup, same music loaded.., same everything..
So, if you have some ideas about your mix you can :
- Try your mix at a later point (move the track position in sync), use different eq's, mixer and knob positions, add effects, loops etc.
- You can even unload the decks, try new tracks, again use the knobs on the controller try what you have in mind, listen how it sounds.
Remember, only you will hear these changes.
How is this possible..
The headphone output changes to split mode where you can prelisten the master output on the right and whatever you do on the left earphone.
When you're done, you can just switch back to normal mode like nothing ever happen.
All settings / sliders / knobs will be at the positions you left them.
Then you can do for "real" what you have tried before.
If you are visiting the VirtualDJ booth at the Expo, don't forget to give it a try!
sounds pretty cool...but no way for me to get to atlanta....:-(
Sounds amazing!!!
wait...what? sounds awesome, how come this feature has´nt been teased before? mind explaining it with a practical example?
A practical example of Sandbox feature :
With Sandbox mode enabled, your live master out will keep playing song out live to master, as if nothing changed.
But the decks in VirtualDJ will be free for the DJ to play around with, without anyone hearing it out live (to master output).
Only you as a DJ will hear this, in your headphones.
So if you have a song playing on say deck A, and you still have minutes left before the end of the song, you might want to activate the sandbox mode, and then you can safely move deck A to a point near the end of the song where you think you might want to do your mix transition, and try to mix with the track on deck B. And even set cue markers, test some effects or scratch cuts, etc to see if they sound cool on this track. You can crossfade, equalize, apply effects, scratch, set cue points for mix out or loop, everything.. and it only be heard in the DJ's headphones.
When you're satisfied you can deactivate sandbox mode, and deck A will return to the "real" song that has been playing on the master output all along as if you had never activated Sandbox mode at all (and deck B will automatically pause, for safety).
And you're ready to do the things you just tested out and found to work good, in Sandbox mode ...
Basically, Sandbox mode is a bit like if you would open a new VirtualDJ on a second computer, load the same songs and song positions, connect your headphones to this other computer, and try your mix and others stuff, while the first computer is still playing the song for the audience. Then return to the first pc playing out live, when satisfied with the testing on the second pc - and be ready to rock ;)
That's clever stuff.
I was looking at the new skin and didn't notice the "shift" knob for loop. Is that what "roll" is for?
Was that meant for me Andrew?
Sandbox sounds good and all but this caters to djs using a midi controller, I don't see this working with a traditional analog mixer. Unless I'm missing something?
56%
