Topic: [NEWS] VirtualDJ 8 Pre-Release - Page: 2
Please provide more information.
ok i have numark cue ...... so do i have to upgrade to use vdj8
Cheers!
In the past, Numark CUE was updated after Numark had a chance to check, test, and inspect the software to their liking. I do not know if that will be the case moving forward but, historically, that is the way it was handled.
Is there a place to find the new mappers for VDJ8? I'm having issues with the NS6, which (obviously) I didn't have before. Also, is there an Android tablet app for controlling like the Apple one? It seems kinda silly not have one but I can't find one.
Is there no Cue crossgrade any more?
seems that there be no x-grades at all
Did you look to see if there was a crossgrade from Cue to VDJ 7.4?? If so I believe you can do that, then be eligible for 8.. Just throwin the idea out there.
I know it used to be possible because there are forum posts which mention it.
So where is the V8 user guide?
If you've installed 8, it's in the same location as your V7 manuals.
/MyDocuments/VirtualDJ/
Perhaps a link to the PDFs via the config would be a good idea.
First Impression: YISSSSSSSSSSSSSS :D
Anyone figure out how to remove the Logo of VDJ when doing video. LOve VDJ but hey I like the new spinning logo options also!
Guys, any idea as to why the volume meter on SR is not working?
in options, turn on advanced (check box right corner) and search for "logo" ;)
thanks guys for the preview release
any way to disable limiter
21%
