Topic: limiter in vdj 8
having major issues with limiter enabled this was a problem 7 also however I was able to correct by disabling it with it enabled it causes all my audio to fade in and out like a worn cassette tape why was the disabling taken away ....
geposted Sun 11 May 14 @ 10:28 pm
If you do have a problem it probably means that otherwise the sound would have been clipping, which would have sounded even worse.
Make sure you don't turn the gain up too high and it should be fine. If you need louder, turn up the volume on your amplifier instead of using the gain controls within VDJ.
geposted Sun 11 May 14 @ 11:28 pm
I set the same settings I have in 7 on the new 8 this was a problem some people in 7 that's why u were able to disable it now u cant no matter what u do with the gains still doesn't change with limiter enable the audio sounds horrible
geposted Sun 11 May 14 @ 11:36 pm
make zero db .5000 instead of 1.0000 leaves enough headroom
change the dbs in what setting
geposted Sun 11 May 14 @ 11:43 pm
Config/audio. Check advance at the top.
geposted Mon 12 May 14 @ 12:10 am
