but if you catch your self before you reach that point theres no way to go back without waiting for the song or record to end cause if you re-engage it goes to the position.
geposted Mon 15 Sep 14 @ 10:17 pm
I understand, that's why I said we'll implement a "timecode_disengage" action.
I just wondered why some said that it's "not like in v7", because afaik v7 was behaving the same.
also, because the comments were "Absolute mode is buggy. Smart mode is more fluid, just with weird behaviors.", I suppose this was referring to something else than just the lack of a timecode_disengage action, no?
geposted Mon 15 Sep 14 @ 11:35 pm
https://www.dropbox.com/s/mljfwihge8cmr8i/absolute%20%281280%20x%20720%29.m4v?dl=0
This a a previous build vid of absolute mode, it still works the same now, you can disregard the comments in the videos - about "how I think the software should work" - as you already explained how absolute mode works in vdj
But a you can see the video - where I can play the track at the beginning and at the end of the record - but not in the center - and also has audio buffer beeps..
I will do another vid - about absolute mode if this bug is not clear enough..
geposted Mon 15 Sep 14 @ 11:54 pm
sclavel wrote :
If you want something changed in smart/absolute mode, you'll need to be more precise.
Most of the betatesters said that smart and absolute was working perfectly now, so...
just to be sure, let me explain how it's supposed to work in virtualdj (and yes, that is not the *exact* same as the competitors, but we dont copy the others, we always try to make something better
3) smart mode:
in smart mode, small needle drops (less than 1 minute) are relative, so it keeps the cues/loops.
bigger needle drops map the full length of the vinyl to the full length of the song.
xgl_dj wrote :
They don't behave the same.. similar, but not the same. Absolute mode is buggy..
Smart mode is more fluid, just with weird behaviors..
3) smart mode:
Ok - I retested smart mode - it is fine by your definition - The weird behavior I was referring to was the track restarting when I move the needle - but I guess I was moving the needled more than 1 minute on the vinyl.
An option to increase the default minute mark - would be great - to me a 1 minute on the vinyl is too short - so an option to increase the minute mark would be good.
Relative Mode = Good
Edit:
Smart Mode = Unstable - A small backspin can cause the track to jump to the end of the track.. Not even a full backspin - from about 4 o'clock to 12'clock.. Smart mode wasn't tested properly..
Absolute Mode = Bug in my video needs to be fixed.
geposted Tue 16 Sep 14 @ 12:18 am
Finally had time to test a bit yesterday.
Had several skips in all modes, not sure wether it's software, carts or vinyl, all are same age & no spares around so no option to swap :D
But what I'm sure is a remaining bug is the pitch
ended up in smart mode & in some cases my pitch on TT was -6 to 7 & when loading a new track, the pitch wouldn't adjust anymore & get out of sync (tt vs software) by about 6%
had to put pitch on TT on 0 again & reset it in the software
geposted Tue 16 Sep 14 @ 2:28 am
Can not be no skip in relative mode what kind of needle do u have and how do u have your tone arm set that it is skiping ?and what beta update are u are on?
geposted Tue 16 Sep 14 @ 3:04 am
last build
shure 447, 23°angle, 3gr weight, 4 height, 0 anti-skating (1200's so s shaped tone-arm)
gonna try to lower the height after work
geposted Tue 16 Sep 14 @ 3:20 am
Your problems sounds unique, all modes work as they should over here except for the bug in absolute mode that xgl pointed out
geposted Tue 16 Sep 14 @ 3:44 am
@dasouth2004
Are you on the latest BETA build 1960?
geposted Tue 16 Sep 14 @ 7:06 am
DJ Koz wrote :
@dasouth2004
yes, i am on 1960
geposted Tue 16 Sep 14 @ 9:20 am
dasouth2004 wrote :
yes, i am on 1960
DJ Koz wrote :
@dasouth2004
yes, i am on 1960
and u are using cdj timecode u left me a message on youtube.it me DJ BIGMIX
geposted Tue 16 Sep 14 @ 11:13 am
no, vdj timecode vinyls
geposted Tue 16 Sep 14 @ 11:25 am
oh ok because u left me a message and u ask me if i was using traktor cd timecode?
but i dont know what could be wrong i have it on relative mode and it not skipping at all on me put a pic of your setting so i an see how u have it?
geposted Tue 16 Sep 14 @ 11:55 am
pic of software settings?
wasn't me who msg'ed you
still at work, will do in the morning
geposted Tue 16 Sep 14 @ 12:14 pm
Sky-Trendsetter - If you got TT's around - no cd players - do a set in smart mode and let me know if it jumps - no drifts but jumps.
angelt99 - could you also do a set in smart mode if you have a chance..
I want to see if it just me who has this issue with jumping, in smart mode - I will see if I can catch this on video, as it is something that does NOT happen all the time, but it happens..
geposted Wed 17 Sep 14 @ 12:01 am
To DEVS
Absolute mode and smart mode has a bug where it doesn't load the entire track from the beginning.
It plays up to a cue point then skips once it gets to the cue point, see video below
geposted Wed 17 Sep 14 @ 8:01 am
