with this setting ..i can see both timecode signal clearly but i can only hear the left deck
geposted Wed 21 May 14 @ 8:06 pm
djrickmhaiti wrote :
using SL1 Rane CDJ 1000 Virtual/Serato timecode... they sounds fine and are precise except that when i cue on the CDJs after 30 seconds of scratching the sample will not be on point to the CDJ marker it will be decreasing counterclockwise!
I don't remember it doing that before!
I experimented with it again to find out it was with the "SCRATCH" video in sampler FX native in VDJ8 that did that to me and all my other scratch mp3 samples and music stayed true to the marker. couple of hiccups for instance I loaded a video and started scratching to see if it was going to change with the marker and suddenly it skipped to another section in the music..
getting better and better each updates!!
geposted Wed 21 May 14 @ 8:11 pm
with this setting ..i can see both timecode signal clearly but i can only hear the left deckyour timecode channels must be the same as the channel that you send the timecode in ex : if you send the left deck to channel 1 than your timecode channel will also be 1. channel 2 = 2 ....it needs to receive the timecode signal make sure that both timecode in the config receive a proper signal.
geposted Wed 21 May 14 @ 8:16 pm
Like this,
deck1 TKZ2 ch1/2
deck2 TKZ2 ch3/4
timecode1 TKZ2 ch1/2
timecode2 TKZ2 ch3/4
deck1 TKZ2 ch1/2
deck2 TKZ2 ch3/4
geposted Wed 21 May 14 @ 8:18 pm
no luck still bud..im thinking it has something to do with the z2 ..everything is going through 1 channel no matter how i change the settings. and the only way i can get to read both timecode signals is to change one of them to 5 &6 . but then again both sounds come out as one channel
geposted Wed 21 May 14 @ 10:18 pm
My Audio 6 uses channels 3&4 and 5&6. Input/output matching for each one. Output 1&2 are used with my CDJ400 on midi, not timecode.
Maybe setting yours like this will work.
geposted Wed 21 May 14 @ 11:12 pm
mini reaper
What's going on my brother long time the problem that you are having I think is that the
TKZ2 ch1/2 and ch3/4 should have a ASIO symbol by it.
deck1 TKZ2 ch1/2 (ASIO symbol)
deck2 TKZ2 ch3/4 (ASIO symbol)
geposted Wed 21 May 14 @ 11:54 pm
Charlie Wilson wrote :
I am glad you enjoyed the video :)
Here is a better one
yeah Charlie! Go,go,go!!!!..he,he...no seriously.hella cool buddy. hey consider recording the output and syncing it with the video on an editor (I use the AVS4you pack) for better sound...but wait a minute who is this?
geposted Thu 22 May 14 @ 12:32 am
beatbreaker1 wrote :
Restart your Mac, samething happens with my SL3 and DJM T1............
xgl_dj wrote :
Mac mid 2012, i5, 4gb Mavericks..
Using a maya 44..
The timecode is super laggy.. Embarrassingly laggy.. I can move the record and it responds 3 seconds later.
I also have an sl1 but I think this is not compatible with vdj 8 on the Mac side...
Using a maya 44..
Shouldn't have to restart.. Should be working anytime I start up the software... I thought you said the timecodes were all good..
geposted Thu 22 May 14 @ 1:02 am
apopsis wrote :
Yes this input signal is very low and you can't expect running timecodes this way.
Tell us more about your soundcard, input settings (check phono / line switch / levels), what timecodes are you using ?
Cd or Vinyl ? If you are using vinyl, what turntables / needles ?
xgl_dj wrote :
Basically the volume is too low which makes vd8 timecodes super laggy.
Using a maya 44.. serato vinyl with techincs 1200's
But like it is the lack of gain controls in vdj because I switch between vdj 7 and vdj8 with vdj giving a much better performance and vdj 7 sounding normal.
BTW - is there a recommended soundcard for timecodes - I will be probably be upgrading to an sl2 or sl3..
geposted Thu 22 May 14 @ 1:12 am
Ok what happens when you use "relative" mode??
"Smart" used to be named "Smart relative" and that's what it was. I don't want to waive needle drop.
From my understanding everything you say is supposed to work like that in "smart" mode because it tracks the position of the timecode where as in "relative" it DOES NOT track the position of the timecode which sounds to me is the way you want it to work.
I want it to behave just as it did before in Smart relative.
The only thing that isn't working was or is that the track stops but even still aren't you moving the needle back to the beginning?? Or are you playing tracks that are longer then 15minutes??
What would I do that for? It's not a real vinyl and scratching on the outer groove is risky from my experience. Also I want the vinyl to wear evenly, why only use the first third over and over again?
Of course I can work around every of those issues (except the weird track loading which I need to restart VDJ for). I don't play tracks that long, but I want the security I had before and since I can't turn tc off and on and change the needle position without skipping and/or having significant speed changes, I would be stuck with tc off to the end of the track which is not what I have a tc setup for.
Also those errors turn up unpredictably, so obviously it's not meant to be, but an effing bug that needs to be fixed. Period.
Long story short:
I wish tc would just be as in 7.4 - but with the smooth touch of 8 I really love.
I wonder if any beta-testers tried timecode before the pre-release - but I cannot imagine the did.
Again, I don't want to nag, I just think it's not the way it's supposed to be - YET.
AND I'm not badmouthing the new version, I like to help and I will gladly do anything on my part to solve this. Also I wouldn't mind beta-testing mysyelf!
geposted Thu 22 May 14 @ 1:50 am
Amen i feel the same way but still waiting for a responds we need to control the timecode set up i posted a pic up and u look at vdj 8 for timecode set up it look like they did not care about us timecode user they just but it there.in vdj 7 u had control of timecode set up we need it back with vdj 8 touch.
geposted Thu 22 May 14 @ 4:59 am
Please don't quote the entire post that is directly above yours. - i have edited :-)
Thanks.
Thanks.
geposted Thu 22 May 14 @ 5:00 am
Hey, Thanks, I will make a better video once I have the skin done and more features added, I need to get some (beg borrow) more cameras and do it properly, it was just a quick demo.
back on topic, I'm using a NI audio 8 with Serato vinyl's and it works like a charm even at the lowest latency settings. Even though the Audio 8 has input gain I liked the input gain controls of VDJ7 to tweek the gain even further but its something that I could live without.
geposted Thu 22 May 14 @ 6:40 pm
