Topic: Custom Skins & Skin Engine - Page: 1
As of now, some version 8 skins are available for download in the usual page. More will come very soon and authors will update the existing ones hopefully, even though most of them should work fine even as they are now.
For the new skins, please post your comments, bugs and requests to the Skins forum (you will see the relative topics soon).
for any other question related in the new Skin Engine in general, please post here. We will make a wiki page very soon to include the new improvements and additions.
Thank you
geposted Mon 12 May 14 @ 5:01 pm
will there be an option in the future or a plugin to download in order to revert the waveforms to look like they did in 7.4? like as in how small and slow they move, and how skinny they become when you zoom in.
geposted Mon 12 May 14 @ 8:08 pm
HomeboyPRO InfinitySupport ManagerMember since 2003
There are several different options for the wavefrom at the top
You can also use your mouse to zoom in and out on most waveforms.
geposted Mon 12 May 14 @ 8:15 pm
jaakkoPRO InfinityMember since 2006
Thank you! Is it possible to update Rusty 4D Swap Multi to VDJ8? That's my favourite skin and I have used it for last two years. Thanks for the hard work!
geposted Tue 13 May 14 @ 12:44 am
gbeulPRO InfinityMember since 2007
Just a short Question
how is it possible to seperate (undog) the Browsersektion ?
i thought that this will be a new feature of V8
Thanks
geposted Tue 13 May 14 @ 3:14 am
Is it possible to Update the skin sektion in download with an option VDJ Version (like a list to select VDJ6/VDJ7/VDJ8 only)
would be helpful to see only the skins for the Version we need
Best regards
geposted Tue 13 May 14 @ 3:17 am
Thanks
Not possible at the moment.
But it is possible for a skin developer to implement this.
geposted Tue 13 May 14 @ 3:18 am
It cannot be done. At least not in the default skin. You also cannot switch it to full screen as in V7.
Apparently there will (or may) be some skins at some point in the future which have the option.
I think it should be made possible in the default skin. Please!
the question i asked was because i whant to use 2 Screens one external wich i could turn (for libaray) and my little 13" MB only for Player and loops etc.
maby we find one how is able to do that
but thanks for that info "i will wait"
geposted Tue 13 May 14 @ 3:25 am
+1 on this idea, please Atomix.
geposted Tue 13 May 14 @ 3:28 am
Still there is no way to revert the waveforms, so it will goes from left to rigth the way its supossed by me to be correct.
geposted Tue 13 May 14 @ 4:35 am
This is deprecated.
geposted Tue 13 May 14 @ 5:42 am
Wont implement that unless there is a fix for the <window>s, sorry.
Ps. dont have to report it. It has been already ;)
geposted Tue 13 May 14 @ 7:29 am
RobRoyPRO InfinitySenior staffMember since 2012
thx...;-)
geposted Tue 13 May 14 @ 7:56 am
djjbPRO InfinityMember since 2004
What happened with the clipmask, mousemask etc?
It's not working in my own skin. I changed the xml into version 8 and did some changes so far.
For the rest it's super.
ps: It seems that the autogain isn't working when a song is not scanned.
Big thanks and best regards,
John
geposted Tue 13 May 14 @ 10:28 am
Clipmask and mousemask are no longer required.
Using PNG graphics with an Alpha (transparent) background you can draw your image as you want it to appear.
Code useing <on> and <off> and VDJ will do the rest.
More information on skins will come shortly after the Full software launch.
geposted Tue 13 May 14 @ 10:30 am
Thank you Guys for the Skins updates as always well cool .
geposted Tue 13 May 14 @ 2:08 pm
It does work if you allow the song to completely load. If you press PLAY before that, then it will not change the GAIN once fully loaded to avoid sudden changes on sound. This is an intentional behavior as some users were complaining that the sound was changing while playing a track.
geposted Tue 13 May 14 @ 2:57 pm
Please, please, please could it be possible to hide deck 3&4 on the default skin but still leave deck 1 & 2 collapsed like on the 4 deck skin so it gives a lot more room for the browser area. This would be much better for controller users who dont need to see huge decks and dont use 4 decks
geposted Tue 13 May 14 @ 7:13 pm
yes.. already almost done with a skin just like that for my own use ;) will share it on site when its ready
18%
