I installed the new VDJ 8 and connected it to my MC6000 and things seem to work ok with a few problems. First of all the headphones PFL functions are not working correctly.
And the biggest problem is that their is no fader volume control. For some reason the Master volume knob and the faders are stuck at maximum. When you move the volume faders you can see a shadow fader moving on the screen but no effect to the volume.
So for now it's back to Version 7 until someone gets the mapping worked out correctly. I am using Windows 7 and have not changed the hardware settings (PC mix).
DJ James
DJ James
geposted Mon 12 May 14 @ 7:49 pm
What are your sound card settings, as it seems to be working fine for me?
geposted Mon 12 May 14 @ 8:01 pm
DJ James
DJ James
James I have been using VirtualDJ 8 with the MC6000 for quite a while. Can you advise what your soundcard settings are? Have you upgraded to the latest firmware provided by Denon?
geposted Mon 12 May 14 @ 8:03 pm
Ok this may be a rookie question but how do you upgrade the firmware and also when I plugged it in it said the plugin was not compatible
geposted Mon 12 May 14 @ 8:35 pm
No I have not upgraded the firmware since I got the unit. But it works fine with VDJ 7.
master DENON DJ ASIO Driver (ASIO) DN-MC6000 1&2
headphones DENON DJ ASIO Driver (ASIO) DN-MC6000 3&4
geposted Mon 12 May 14 @ 8:43 pm
Please update the fimrware to be sure that is not the issue. As I said I have been using the 6000 with VDJ 8 for some time.
geposted Mon 12 May 14 @ 8:48 pm
I have a similar issue, but mine is only on MC600 as EXTERNAL MIXER!!!
No way to solve this headphone situation.
geposted Mon 12 May 14 @ 9:07 pm
Updated firmware and asio driver. Now fader for channel 2 will move fader on channel 1 of software. Other faders do nothing but make the shadow fader move.
My settings are for Dennon MC6000 with headphones.
DJ James Back to version 7. Uggg!
geposted Mon 12 May 14 @ 9:49 pm
This is very dissapointing. I have heard that the Denon DN-MC6000 is one of the most popular and widely used controllers on the market.
This should have been working native right from the get go.
Maybe I am doing something wrong in the settings but they are the same settings as version 7.
DJ James
DJ James
geposted Mon 12 May 14 @ 9:55 pm
I just hooked up mine and it seems to be working ok except for the incompatible message on start up (latest firmware), cues work, song preview works. Decks are on the middle 2 faders on the Denon vs 1 & 2 with v7.
I have noticed the wheels may need some adjustment, they don't seem that responsive at times.
Currently using it in "PC Mix" mode on a mac
Audio settings:
Master | Denon-MC6000 | Chan 1&2 | 48khz, 512 sample (picked automatically)
Headphones | Denon-MC6000 | Chan 3&4 | 48khz, 512 sample (picked automatically)
Audio settings:
geposted Mon 12 May 14 @ 10:05 pm
jamesvanek wrote :
[quote=Homeboy]
Try the little white dot just above the cross fader (on the v8 4deck skin)
geposted Tue 13 May 14 @ 12:11 am
Tried that. All different variations. Still maxed out. And no control.
DJ James
DJ James
geposted Tue 13 May 14 @ 1:24 am
Could you download this Skin please
http://www.virtualdj.com/addons/16707/COMBAT.html
If I remember correct this skin provides an option to switch between 3124 and 1234 mixer mode.
I think the default Skin is working in 1234 but the denon uses 3124.
geposted Tue 13 May 14 @ 2:59 am
Make sure your mixer is set to "pc Mix"
You have to use the 2 center channels for VDJ 8, I used to use the outer 2 channels and when i installed VDJ 8 I had the same issue.
Hope this helps
Hope this helps
geposted Tue 13 May 14 @ 3:57 am
Same problems for me, but there seems to be two threads running on this now which is a shame.
'This plug in is not compatible' message pops up randomly and it also activated with the Fx1 dial in the top left hand side of the controller.
If you want to use the controller in external mix mode, I believe you have to select external controller in the sound card option in VDJ settings.
geposted Tue 13 May 14 @ 6:13 am
And making sure your mixer is set to PC Mix is not an option. Pc vs Int mix is not an option, it's a preference that is used for very different reasons.
geposted Tue 13 May 14 @ 6:15 am
I agree. I've got mine set up as external mixer (switch on the back to int. mix), audio setup Deck 1 = audio out 1 & 2, Deck 2 = audio out 3 & 4. Headphones are working through the internal PFL.
The error on start up might be caused by the V7-version of Beatgrid. That's also the first soundeffect selected when you turn your Effects selector (because of the alphabetic order). I haven't removed mine yet, because I have a gig next weekend and I'm not confident enought to run that on V8.
If I recall correctly, I had some trouble assigning Deck 1 & 2 to the channels 2 & 3. There was no 3-1-2-4 option in the controllersetup in V8. I've tried to run Zanek's MC6000-skin and later I found out that I did have a 3-1-2-4 setting. Might have something to do with the skin, but not sure.
If you want, I can try to post my steps tonight (I'm home in about 5 hours).
BTW: Running my MC6000 in V8 with ASIO on 4 ms..... That's quite a difference!
geposted Tue 13 May 14 @ 6:38 am
Hope this helps
Hope this helps
Yep that was it. Before in version 7 it used channels 1 and 2. Now using channels 2 and 3. Also when you see the shadow fader you have to move it up to meet the actual fader then they will be in sync and everything is fine.
Moderator can mark this one as solved.
Thanks,
DJ James :)
geposted Tue 13 May 14 @ 12:17 pm
I'm having similar issues with the 3000, 6000, and 6000MK2. All three of them work perfectly fine within 7.4.1, however none of them work properly in 8. (Locked knob settings, and this never ending headphone issue.)
geposted Wed 14 May 14 @ 10:56 pm
hey guys im having issues with my denon mc6000 cant get volumes to work like normal on cue points to headphones what am i doing wrong im a monthly suscriber i got master 1&2 & headphones 3&4 and im using channels 1 & 4 on midi but nothing
geposted Fri 23 May 14 @ 4:48 pm
