Topic: VDJ activating discrete gpu on mac
Is there any reason why the discrete gpu kicks in whenever I launch virtual dj? I'm running mavericks i7 2.2ghz radeon hd 6750m.
geposted Mon 12 May 14 @ 11:15 pm
So nobody else has this problem?
geposted Tue 13 May 14 @ 11:38 am
JeremKPRO InfinityModeratorMember since 2004
Does your Mac get very hot whenever you open VirtualDJ 8 ?
geposted Tue 13 May 14 @ 12:02 pm
my Mac is getting unusually hot, compared to 7.4
geposted Tue 13 May 14 @ 12:03 pm
Yes the temp goes up to like 88 degrees. I have gfxcardstatus, I have to set it to use integrated only. Whenever I open vdj for a test run, the discrete graphics automatically turns on. In previous versions the only time it ever activates the gpu is when I load a video or when i enable video.
In the options ''startvideoonload'' is set to ''no''
geposted Tue 13 May 14 @ 12:37 pm
Haui70PRO InfinitySenior staffMember since 2008
Regarding the heating, please set skinFPS to 20.
Then try it again :-)
geposted Wed 21 May 14 @ 9:23 am
