Spent hour last night reading the manual then jumped in a tried to use Track cleaner to remove dead bit of video followed the instructions with no result. Sandbox only on 2 deck skin again read manual but could not open it, any help welcome
geposted Tue 13 May 14 @ 6:47 am
Sandbox only works if
- no external mixer is used (just midi controllers)
- no video file is loaded
- only 1 deck is playing over master out
- another thing i just forgot :P
geposted Tue 13 May 14 @ 6:50 am
what about Track cleaner? anybody help
geposted Tue 13 May 14 @ 7:47 am
You have to right click on the song in the browser not on the track, then a option screen will open with a choice of editors. In my opinion this was a bad way to impliment the editors. These option can be embedded in the waveform box it self
geposted Tue 13 May 14 @ 8:24 am
i Have an example which seems to get no attention....tell me what you think of the option i advise
http://www.virtualdj.com/forums/187389/VirtualDJ_8_Pre-Release_Forum/Editing_options.html
geposted Tue 13 May 14 @ 8:30 am
To remove a section of VIDEO - you need the Video Editor not the track cleaner!!
geposted Tue 13 May 14 @ 9:04 am
i was able to remove some profanity on a song track, with windows 7 pc.. Took a while to figure it out but it works and i love it.
geposted Tue 13 May 14 @ 10:19 am
I must be doing something wrong I've tried Video Editor hi-lighted the area clicked waste bin and nothing. I thought I could cut a portion of video out.
I do now however understand sandbox & track cleaner does not work on videos.
geposted Tue 13 May 14 @ 11:36 am
I just read the manual. Sandbox will not work for videos. That's a bummer :(. I am Video DJ so I can never use it. Hope there are plans to allow sandbox for video in the future.
geposted Tue 13 May 14 @ 11:48 am
Ok, i got myself confused.
To remove a section of the track (including video) use the track cleaner.
Now when the track saves it save a a VDJEDIT file - the original track is unchanged.
I recommened adding a filter folder so you can access you edited tracks easier (note also they will have a spanner on the icon).
For the filter folder use this criteria:
File Type is 'vdjedit'
- Locate the original track
- Rightclick and select Track Editor
- Click REMOVE
- You will see a yellow box on the waveform.
- Position this where you want it. You can zoom in using you mouse wheel to get it accurate.
- Press Save
geposted Tue 13 May 14 @ 11:53 am
Hopefully in the future. ;-)
donde consigo el manual en español de virtual dj 8 solo lo encuentro en inges quien me puede ayudar
geposted Tue 27 May 14 @ 2:05 pm
Sorry this is an English Speaking Forum
Please post your message again in English or use the language forums at the bottom.
Thanks.
Thanks.
geposted Tue 27 May 14 @ 2:10 pm
