Loving the new version. I had a gig at a local bar last night. I knew there was a possibility of a software crash since this is a prerelease version, however, I was stable for me all day, so I decided to use the new version. Everything was great, but in the middle of a video (all video gig), The software would crash without warning. The recover all of I would have to do is restart VDJ8 and on most crashes it would return the same status as when the crash occurred. However, I would alway have to go into the config and select external mixer VMS4.1 When I would hit apply, then the sound and the video would be active again.
What I was using at the time of all crashes:
1. VMS4.1
2. Using MacBook Pro (system info at the bottom of this post).
3. using a video adapter from a Lightning port adapter. (Can't use the HDMI because it overloads the antiquated video converter used by the club to feed it's monitors).
4. Streaming the mix to LIVE365 direct using the shout cast settings.
In order the stream to live 365, I had to add "master - ch. 1 &2 - Internal sound card output. (see graphic below).
(would have to go in config re-input the info and restart the stream each time). SEE sound card settings graphics below).
Program working perfectly except the unpredictable crashes. I will have an external sound source plugged in so there won't be any awkward silence next time). Love the program.. It is great!
Here is my Mac INFO:
Model Name: MacBook Pro
Model Identifier: MacBookPro11,1
Processor Name: Intel Core i5
Processor Speed: 2.6 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache (per Core): 256 KB
L3 Cache: 3 MB
Memory: 8 GB
Boot ROM Version: MBP111.0138.B03
SMC Version (system): 2.16f58
Serial Number (system): C02LK71DFH01
Hardware UUID: 6A26E596-BAA7-5EE9-AA64-2C899B815D4D
AND HERE IS THE GRAPHIC OF MY UNUSUAL SOUND SET UP:
1. VMS4.1
L3 Cache: 3 MB
Memory: 8 GB
geposted Wed 14 May 14 @ 3:29 am
geposted Wed 14 May 14 @ 3:37 am
Indeed your Sound Setup seems unusual and honestly never thought that Master and External mixer could coexist in the same audio Setup.
Is there a reason why you dont use RecordLoopback and the Booth Output of the VMS4 to a the Line In of your computer ?
Btw, i suppose that the crashes you were getting were not related to any specific video files,right ? Have you also noticed high temperature on your computer while playing video ?
Can you reproduce the crash at home ?
Can you try to set your Built In Output to 44.1Khz next time (if possible) ?
geposted Wed 14 May 14 @ 3:43 am
The software auto-launches after a crash, but since you said that you will have a backup solution next time, then maybe you could help us by catching the crash report.
to do this, set the crashGuard setting (Advanced Settings in CONFIG) to yes. This will allow your Mac to provide a Report rather than relaunching automatically. Copy-paste the content of that report and post it here or create a text file with the content, upload it (to a server or Dropbox) and post the link here.
Thanks
Thanks
geposted Wed 14 May 14 @ 3:57 am
Thanks for the quick response.
1. Not sure how to use the loop back settings. If VDJ still sends the song data for DRM to Live365's server, then that would work. I just have to research the loopback to figure out how to do it. If Live365 is receiving a stream from the VDJ server without DRM. It drops the live feed and reverts to the standby playlist which is on the Live365 server and is DRM compliant.
2. Regarding the crash. Doesn't appear tied to any particular video. Virtually all of the videos I play, are Promo Only HD videos at 720p. It was never the same video that caused the problem.
2. There were a couple of times when I got the mac "beach ball" (our version of the Windows hourglass) and the problem would lock. (Occurred in testing at home. Couldn't even get to the "force quit" selections a a couple of times. When I could, it would show VDJ not responding).
3.No overheating of my mac. Shows very low processor use (on VDJ software interface)
4. One thing I forgot to mention was i was using a JPG (non virtual DJ) club logo activated the whole time.
5. Noticed one other thing: When I would switch between sampler groups, it would cause a click in the output audio.
I will enable the crash guard and capture data when it happens again. I'm leaving town today, so I won't be able to test the configuration that was causing the problem since I won't be taking my VMS4.1 controller and Digital sound processor since I'm flying. will return Monday night. Hope to do some testing later this evening. will probably just put it on auto play with a long playlist. To see if anything happens.
Broadcast Issue: Now I've got to research the loop back possibility. The problem I have with streaming is that anything I cue goes out over the air so when I'm live, I'm mixing by sight. Also I have to pre-record and load into the sampler any "voice over - shootouts plugging the club and my location, then play them back via the sampler during the show. If loopback includes the VMS4 master output, then that would solve the live mic problem. I was at the Miami 4 hour seminar on VDJ 8 - One of the VDJ people said they thought they had solved the cueing issue going out on the air in the new version.
Love the new software.. Will use it a again at the small club gig next Tuesday (with the work around to keep backup audio going, if the crash issue recurs)
geposted Wed 14 May 14 @ 2:23 pm
One question. Looks Like Crash Guard is enabled in my advance options settings.
I looked for a crash guard report from last night's crashes and didn't find any reports in the documents folder nor doing a search in my hard drive and external drive I use for my music source. In the Wiki, it mentioned a folder a Virtual DJ in My Documents (probably a windows term) I looked for the Virtual DJ folder in the document folder on my mac, and found it but no crash reports or crash folder.
TWO question. in my settings Crashguard is set for YES. the option below it is crash guard level. It is set to 0. What setting should I use for this option.
Allen
Allen
geposted Wed 14 May 14 @ 6:13 pm
anyone know the answer the crash guard question above?
geposted Fri 16 May 14 @ 6:06 pm
sorry, my bad. Crashguard to No. It will report a crash if that happens again.
geposted Fri 16 May 14 @ 6:19 pm
I returned crash guard setting to NO.. and charged crash guard level back to 0
Allen
Allen
geposted Sat 17 May 14 @ 1:35 pm
Never did get an answer to the question of should I change the crash guard level from 0 to some other number. In my live mix last night I had 6 crashes but only one file was created. I'm assuming that the file simply overnights itself.. on each crash. There was very tilled data included in the crash guard file. I've cut and pasted the content at the end of this message.
I am going back to VDJ 7 Pro for my club performances, because even with back up audio (which I had last night), it still caused a break in the flow of the music temporarily... or about 10 seconds of silence until I could the play button on the iPhone I was using as my alternate music source. I can't wait of the new version to finally be stable for me on the Mac Platform. It's a major improvement. I will continuing testing Version 8 and will report any anomaly that I find. so if you can let me know what to set the crash guard level for, it might be productive.
Freeze (date=1311032235, version=7.4 Pro - mac, build=453, thread=Internet)
geposted Wed 21 May 14 @ 2:34 pm
I have this problem on my mac .... search a song then press arrow up and arrow down look for the song i search and then open and close VDJ8 then search again and VDJ8 crash ..... Help this is horrible on MAC on PC dont have this problem
geposted Thu 22 May 14 @ 9:03 pm
@JarheadDJ Are you using a Mac computer with OSX or Windows ? Confused sorry. If you run windows then the crashes get uploaded automatically. Are you using a Wifi connection btw ?
@edwinaltamiranovdj Please dont hikack threads and dont cross-post, thank you
geposted Thu 22 May 14 @ 9:49 pm
DJ dad -- Still need to know what Crash guard level should be set to. It is currently set to zero.
---RE: current questions.
Yes using a MacbookPro only. I posted my audio set up higher up in the thread but will cut and past it at the end of this dialogue.
Yes, I have to use WIFI to do my remote broadcast. WIFI has never created a problem at the location where I'm doing this while using VDJ7.
Also, note: I had no problems switching back to VDJ 7 this past weekend (with wifi - but not broadcasting) on two nights video gigs at another night club. Saturday was a six hour gig and the Sunday night gig was four hour gig.
(BTW I miss my VDJ8 interface! But it's early in prerelease... so ... understand -- also, I haven't done any testing yet since the most recent upgrade.)
Here is the info from the earlier post about my system -- also, I'll move down a past of the one crash guard report I have.
As always.. you have know idea how much I appreciate you and your rapid responses.
CRASHGUARD REPORT:
I didn't notice.. but the crash guard report was for a crash of Ver 7.4 Pro.... so it won't be any help. I guess it was created after i switched back to VDJ7. VDJ 7.4 did crash once when I first switched back and required a compute computer restart. I'm thinking I will startout using VDJ 8 Tuesday night. If I do get another crash, I will switch back to VDJ7 Pro. That way we will at least have a VDJ8 crash report.
Here is the VDJ 7 crash report which is the only one I found in my folder.
1. VMS4.1
L3 Cache: 3 MB
Memory: 8 GB
CRASHGUARD REPORT:
1. VMS4.1
L3 Cache: 3 MB
Memory: 8 GB
geposted Tue 27 May 14 @ 12:11 am
when I disables the coverflow and coverdownload in options I have less crash with vdj8 on mac pro.
dj guad
dj guad
geposted Tue 27 May 14 @ 3:28 pm
Thanks I'll give that a try.
geposted Wed 28 May 14 @ 8:59 pm
worst crash ever with VDJ8 tonight Ver 1819.673. VDJ froze when accessing a Promo Only High Def video. only recovery was to force quit VDJ8 and then restart the computer. It apparently corrupted the video file when opening via Preview -- only the first ten seconds or so .. of the video and audio was there. the rest was just blank. I deleted the file then overwrote it with a copy from my back up.
There was no crash guard report: I lost the macbook pro error report that was sent to apple.
geposted Sun 01 Jun 14 @ 2:59 am
VDJ only writes to a file when you select 'Write Tag' from the Tag Editor, so I'm not sure how the file got corrupted.
Any idea of the temperature of the computer perhaps? Although if it gets too hot it should throttle down or turn off by itself.
geposted Sun 01 Jun 14 @ 3:11 am
Is your option "setTagsAuto" set to "yes"?
geposted Sun 01 Jun 14 @ 7:14 am
setTagsAuto is set to NO.
No overheating or over taxing CPU. In Fact CPU is showing low to moderate usage (based the indicator in the VDJ interface).
I wish I could have captured the apple crash report.
Crash guard set to NO (based on instructions earlier in this thread)
Never did get a response from the thread where to set crash guard level. It defaults to 0. Should it be set to a number?
Thanks all for any help.
I am doing my major gigs with VDJ7Pro.. It's running fine. VDJ8 is so much better and the sound is so much better. Can't wait for it to stop crashing on me. Being patience.. I know this is a major from the ground rewrite.
geposted Mon 02 Jun 14 @ 9:44 pm
PROBLEM SOLVED. - After experience an unexpected crash using VDJ7 PRO over the weekend at a gig, I erased my hard drive in my MacBook Pro an reinstalled the operating system. Then I restored my programs and documents from Time Machine. The complete restore I had done previously left stuff form all of the versions of the operating system which had been ported over to my Late December 2013 MacBook Pro from my 2008 MacBook Pro. The system performance and start up and shut down times are lightning quick now. So for VDJ8 This apparently did the trick.
I ran an auto mix test with video for 6 hours and there was no crash. I used Version 8 at my night club gig last night... with no problems. I did have one crash, but I'm pretty sure I caused it by not operating the program properly when doing searches. (I was broadcasting live and using the internet Safari browser doing some external searches at the time as well as some in-VDJ 8 searches at the time the crash occurred. Once I rebooted the computer and reopened the program, it was flawless for the remaining hour and half of the gig. So for the Five-Hour gig VDJ8 was as stable or more stable than VDJ 7 Pro. I'm feel this multiple crash problem as been solved. I am now going to use VDJ 8 for all of my gigs. Thanks for all of the assistance.
No crash guard report was issued. However here is the Mac technical report that was automatically sent to Apple:
Process: VirtualDJ [386]
Path: /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
Identifier: com.atomixproductions.virtualdj
Version: 8.0.0 (8.0.1828)
Code Type: X86-64 (Native)
Parent Process: launchd [165]
Responsible: VirtualDJ [386]
User ID: 504
Date/Time: 2014-06-10 23:48:13.527 -0400
OS Version: Mac OS X 10.9.3 (13D65)
Report Version: 11
Anonymous UUID: C45682C1-4927-AEFA-4AF6-DEA9BF062B92
Crashed Thread: 15
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000013f5c8000
VM Regions Near 0x13f5c8000:
MALLOC_LARGE 000000013f52b000-000000013f5c8000 [ 628K] rw-/rwx SM=PRV
IOKit 000000013f614000-000000013f764000 [ 1344K] rw-/rw- SM=SHM
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00000001114bca1a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00000001114bbd18 mach_msg + 64
2 com.apple.CoreFoundation 0x000000010e258fc5 __CFRunLoopServiceMachPort + 181
3 com.apple.CoreFoundation 0x000000010e2585e9 __CFRunLoopRun + 1161
4 com.apple.CoreFoundation 0x000000010e257f25 CFRunLoopRunSpecific + 309
5 com.apple.HIToolbox 0x00000001121bba0d RunCurrentEventLoopInMode + 226
6 com.apple.HIToolbox 0x00000001121bb7b7 ReceiveNextEventCommon + 479
7 com.apple.HIToolbox 0x00000001121bb5bc _BlockUntilNextEventMatchingListInModeWithFilter + 65
8 com.apple.AppKit 0x000000010f34926e _DPSNextEvent + 1434
9 com.apple.AppKit 0x000000010f3488bb -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 122
10 com.apple.AppKit 0x000000010f33c9bc -[NSApplication run] + 553
11 com.atomixproductions.virtualdj 0x000000010c16a7c4 0x10bd91000 + 4036548
12 com.atomixproductions.virtualdj 0x000000010c39bd44 0x10bd91000 + 6335812
13 com.atomixproductions.virtualdj 0x000000010c318b85 0x10bd91000 + 5798789
14 com.atomixproductions.virtualdj 0x000000010c2e6121 0x10bd91000 + 5591329
15 com.atomixproductions.virtualdj 0x000000010c1337da 0x10bd91000 + 3811290
16 com.atomixproductions.virtualdj 0x000000010c3473c7 0x10bd91000 + 5989319
17 com.atomixproductions.virtualdj 0x000000010be79552 0x10bd91000 + 951634
18 com.atomixproductions.virtualdj 0x000000010bd92a14 0x10bd91000 + 6676
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00000001114c1662 kevent64 + 10
1 libdispatch.dylib 0x00000001112ea421 _dispatch_mgr_invoke + 239
2 libdispatch.dylib 0x00000001112ea136 _dispatch_mgr_thread + 52
Thread 2:
5 com.apple.AppKit 0x000000010f4e905e _NSEventThread + 144
6 libsystem_pthread.dylib 0x00000001115c6899 _pthread_body + 138
7 libsystem_pthread.dylib 0x00000001115c672a _pthread_start + 137
8 libsystem_pthread.dylib 0x00000001115cafc9 thread_start + 13
Thread 3:
0 libsystem_kernel.dylib 0x00000001114c0716 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00000001115c8c3b _pthread_cond_wait + 727
2 com.atomixproductions.virtualdj 0x000000010be6e20d 0x10bd91000 + 905741
3 com.atomixproductions.virtualdj 0x000000010bd98d43 0x10bd91000 + 32067
4 com.atomixproductions.virtualdj 0x000000010bd98d0d 0x10bd91000 + 32013
5 libsystem_pthread.dylib 0x00000001115c6899 _pthread_body + 138
6 libsystem_pthread.dylib 0x00000001115c672a _pthread_start + 137
7 libsystem_pthread.dylib 0x00000001115cafc9 thread_start + 13
Thread 4:
2 com.atomixproductions.virtualdj 0x000000010be6e259 0x10bd91000 + 905817
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
2 com.apple.audio.midi.CoreMIDI 0x000000010e18b5a7 XServerMachPort::ReceiveMessage(int&, void*, int&) + 125
3 com.apple.audio.midi.CoreMIDI 0x000000010e1a61c1 MIDIProcess::RunMIDIInThread() + 121
4 com.apple.audio.midi.CoreMIDI 0x000000010e18c63c XThread::RunHelper(void*) + 10
5 com.apple.audio.midi.CoreMIDI 0x000000010e18c2a1 CAPThread::Entry(CAPThread*) + 109
Thread 12:
Thread 13:
Thread 14:
Thread 15 Crashed:
0 libsystem_platform.dylib 0x00000001115abb29 _platform_memmove$VARIANT$Unknown + 41
1 com.atomixproductions.virtualdj 0x000000010bef4119 0x10bd91000 + 1454361
2 com.atomixproductions.virtualdj 0x000000010bef44fd 0x10bd91000 + 1455357
3 com.atomixproductions.virtualdj 0x000000010c07dd0c 0x10bd91000 + 3067148
4 com.atomixproductions.virtualdj 0x000000010bd98d39 0x10bd91000 + 32057
5 com.atomixproductions.virtualdj 0x000000010bd98d0d 0x10bd91000 + 32013
Thread 16:
Thread 17:: com.apple.audio.IOThread.client
0 com.atomixproductions.virtualdj 0x000000010c66382c 0x10bd91000 + 9250860
1 com.atomixproductions.virtualdj 0x000000010c65ec61 0x10bd91000 + 9231457
2 com.atomixproductions.virtualdj 0x000000010c66061f 0x10bd91000 + 9238047
3 com.atomixproductions.virtualdj 0x000000010bfc99fa 0x10bd91000 + 2329082
4 com.atomixproductions.virtualdj 0x000000010bfca19e 0x10bd91000 + 2331038
5 com.atomixproductions.virtualdj 0x000000010bf3d7b4 0x10bd91000 + 1755060
6 com.atomixproductions.virtualdj 0x000000010c046348 0x10bd91000 + 2839368
7 com.atomixproductions.virtualdj 0x000000010bde2a24 0x10bd91000 + 334372
8 com.atomixproductions.virtualdj 0x000000010bde297d 0x10bd91000 + 334205
9 com.atomixproductions.virtualdj 0x000000010c07ff78 0x10bd91000 + 3075960
10 com.atomixproductions.virtualdj 0x000000010c07fa12 0x10bd91000 + 3074578
11 com.apple.audio.CoreAudio 0x000000010e12eacb HALC_ProxyIOContext::IOWorkLoop() + 3667
12 com.apple.audio.CoreAudio 0x000000010e12dbcd HALC_ProxyIOContext::IOThreadEntry(void*) + 97
13 com.apple.audio.CoreAudio 0x000000010e12da8d HALB_IOThread::Entry(void*) + 75
14 libsystem_pthread.dylib 0x00000001115c6899 _pthread_body + 138
15 libsystem_pthread.dylib 0x00000001115c672a _pthread_start + 137
16 libsystem_pthread.dylib 0x00000001115cafc9 thread_start + 13
Thread 18:: com.apple.audio.IOThread.client
2 com.apple.audio.CoreAudio 0x000000010e12f918 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 98
3 com.apple.audio.CoreAudio 0x000000010e12f8a6 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
4 com.apple.audio.CoreAudio 0x000000010e12e02e HALC_ProxyIOContext::IOWorkLoop() + 950
5 com.apple.audio.CoreAudio 0x000000010e12dbcd HALC_ProxyIOContext::IOThreadEntry(void*) + 97
6 com.apple.audio.CoreAudio 0x000000010e12da8d HALB_IOThread::Entry(void*) + 75
7 libsystem_pthread.dylib 0x00000001115c6899 _pthread_body + 138
8 libsystem_pthread.dylib 0x00000001115c672a _pthread_start + 137
9 libsystem_pthread.dylib 0x00000001115cafc9 thread_start + 13
Thread 19:
Thread 20:
2 com.atomixproductions.virtualdj 0x000000010cb38072 0x10bd91000 + 14315634
3 libsystem_pthread.dylib 0x00000001115c6899 _pthread_body + 138
4 libsystem_pthread.dylib 0x00000001115c672a _pthread_start + 137
5 libsystem_pthread.dylib 0x00000001115cafc9 thread_start + 13
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
0 libsystem_kernel.dylib 0x00000001114c0e6a __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00000001115c7f08 _pthread_wqthread + 330
2 libsystem_pthread.dylib 0x00000001115cafb9 start_wqthread + 13
Thread 26:
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 15 crashed with X86 Thread State (64-bit):
rax: 0x000000013f52b000 rbx: 0x00007fca52dec510 rcx: 0x000000000000bc00 rdx: 0x00000000000a8c00
rdi: 0x000000013f5c8000 rsi: 0x000000015cb83000 rbp: 0x00000001227b5cb0 rsp: 0x00000001227b5cb0
r8: 0x000000000000bb80 r9: 0x00006080003d8420 r10: 0x00007fca51c79100 r11: 0xffffffffe2a45000
r12: 0x00007fca52dec360 r13: 0x0000000000000002 r14: 0x00006080003d8360 r15: 0x0000000000000000
rip: 0x00000001115abb29 rfl: 0x0000000000010206 cr2: 0x000000013f5c8000
Logical CPU: 0
Error Code: 0x00000006
Trap Number: 14
Binary Images:
0x10bd91000 - 0x10d370f27 +com.atomixproductions.virtualdj (8.0.0 - 8.0.1828) <2B34D898-E5A1-308F-BB48-E5F7643963E4> /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
0x10dbc4000 - 0x10dbd1ff7 +com.googlecode.google-breakpad (1.0) <9A5F89A4-5EA3-339F-BC47-6DF8D64238C6> /Applications/VirtualDJ 8.app/Contents/Frameworks/Breakpad.framework/Versions/A/Breakpad
0x10dbe7000 - 0x10dc30fff com.apple.CoreMedia (1.0 - 1273.54) <CAB7303A-9AB2-317A-99C3-BEAA8AE8764B> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x10dc5f000 - 0x10dd81fff com.apple.avfoundation (2.0 - 651.12.1) <FF001F98-E198-3B1D-A7EB-A8C48E6E34A3> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x10de9b000 - 0x10dec0ff7 com.apple.CoreVideo (1.8 - 117.2) <3A7DFC2B-FB92-3471-9387-EEB226730FAA> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x10dedc000 - 0x10dee1fff com.apple.DiskArbitration (2.6 - 2.6) <A4165553-770E-3D27-B217-01FC1F852B87> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x10deeb000 - 0x10deebfff com.apple.CoreServices (59 - 59) <6FC551EB-A6B5-3570-B8D6-9DE481F8B2E4> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x10def4000 - 0x10def4fff com.apple.Accelerate (1.9 - Accelerate 1.9) <509BB27A-AE62-366D-86D8-0B06D217CF56> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x10def7000 - 0x10df3cfff libcurl.4.dylib (78.92.2) <FE790105-B56B-3972-96F4-E133764FF735> /usr/lib/libcurl.4.dylib
0x10df4e000 - 0x10df5bff0 libbz2.1.0.dylib (29) <0B98AC35-B138-349C-8063-2B987A75D24C> /usr/lib/libbz2.1.0.dylib
0x10df65000 - 0x10e044fff libcrypto.0.9.8.dylib (50) <FD04D29B-295E-39D3-9AB8-A28AE74387D1> /usr/lib/libcrypto.0.9.8.dylib
0x10e0b2000 - 0x10e0e6fff libssl.0.9.8.dylib (50) <B15F967C-B002-36C2-9621-3456D8509F50> /usr/lib/libssl.0.9.8.dylib
0x10e0fe000 - 0x10e0feffd com.apple.audio.units.AudioUnit (1.10 - 1.10) <68B21135-55A6-3563-A3D6-3E692A7DEB7F> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x10e107000 - 0x10e158ff3 com.apple.audio.CoreAudio (4.2.0 - 4.2.0) <9170DD01-4927-3F7E-86F4-A029E0E77EA6> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x10e17e000 - 0x10e1b9ff2 com.apple.audio.midi.CoreMIDI (1.10 - 88) <1EA92CDE-75AB-354C-99E5-BB5763AF988C> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x10e1e8000 - 0x10e3cdfff com.apple.CoreFoundation (6.9 - 855.16) <A63E680E-E4B2-368B-8564-9DBE0D8DDB91> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x10e545000 - 0x10e556ff7 libz.1.dylib (53) <4C5FA1A5-4471-398E-9543-2E54D46E63E9> /usr/lib/libz.1.dylib
0x10e563000 - 0x10e654ff9 libiconv.2.dylib (41) <BB44B115-AC32-3877-A0ED-AEC6232A4563> /usr/lib/libiconv.2.dylib
0x10e669000 - 0x10e669fff com.apple.Carbon (154 - 157) <45A9A40A-78FF-3EA0-8FAB-A4F81052FA55> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x10e672000 - 0x10e7a8ffc com.apple.WebKit (9537 - 9537.75.14) <81BB019D-78E2-3CD9-B148-5F5EA5357D2B> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x10e89f000 - 0x10e8adfff com.apple.opengl (9.6.1 - 9.6.1) <B22FA400-5824-36AF-9945-5FEC31995A0E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x10e8b8000 - 0x10ea0cff3 com.apple.audio.toolbox.AudioToolbox (1.10 - 1.10) <69B273E8-5A8E-3FC7-B807-C16B657662FE> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x10eaa7000 - 0x10eb13fff com.apple.framework.IOKit (2.0.1 - 907.100.13) <057FDBA3-56D6-3903-8C0B-849214BF1985> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x10eb4f000 - 0x10eb4ffff com.apple.Cocoa (6.8 - 20) <CCD8E6F3-9B17-3B50-9E6A-DE9A081EE440> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x10eb55000 - 0x10ee53fff com.apple.Foundation (6.9 - 1056.13) <2EE9AB07-3EA0-37D3-B407-4A520F2CB497> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x10f095000 - 0x10f242f27 libobjc.A.dylib (551.1) <AD7FD984-271E-30F4-A361-6B20319EC73B> /usr/lib/libobjc.A.dylib
0x10f266000 - 0x10f2b8fff libc++.1.dylib (120) <2CB96D10-1E3E-39B1-B90D-C56C3818321E> /usr/lib/libc++.1.dylib
0x10f314000 - 0x10f315ff7 libSystem.B.dylib (1197.1.1) <E303F2F8-A8CF-3DF3-84B3-F2D0EE41CCF6> /usr/lib/libSystem.B.dylib
0x10f31d000 - 0x10f31dfff com.apple.ApplicationServices (48 - 48) <3E3F01A8-314D-378F-835E-9CC4F8820031> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x10f325000 - 0x10fe9bff7 com.apple.AppKit (6.9 - 1265.20) <D2A7AF23-0FEA-3D7D-9CF5-B4E262224577> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x110626000 - 0x11064bff7 +breakpadUtilities.dylib (1) <753EEC59-5853-36C1-BD7A-CB38123F77E5> /Applications/VirtualDJ 8.app/Contents/Frameworks/Breakpad.framework/Versions/A/Resources/breakpadUtilities.dylib
0x110664000 - 0x1106b2ff9 libstdc++.6.dylib (60) <0241E6A4-1368-33BE-950B-D0A175C41F54> /usr/lib/libstdc++.6.dylib
0x11071e000 - 0x110760ff7 libauto.dylib (185.5) <F45C36E8-B606-3886-B5B1-B6745E757CA8> /usr/lib/libauto.dylib
0x11077b000 - 0x11077cff7 libDiagnosticMessagesClient.dylib (100) <4CDB0F7B-C0AF-3424-BC39-495696F0DB1E> /usr/lib/libDiagnosticMessagesClient.dylib
0x110787000 - 0x11093fffb libicucore.A.dylib (511.32) <A7CE7DAD-D3AD-36A2-BE4F-25C5F21FADBB> /usr/lib/libicucore.A.dylib
0x1109e8000 - 0x110acfff7 libxml2.2.dylib (26) <A1DADD11-89E5-3DE4-8802-07186225967F> /usr/lib/libxml2.2.dylib
0x110b07000 - 0x110c77ff4 com.apple.CFNetwork (673.4 - 673.4) <F3BF6020-99BE-3844-A7B8-352B93AD02F3> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x110d7f000 - 0x110de2ffb com.apple.SystemConfiguration (1.13.1 - 1.13.1) <2C8E1A73-5AD6-3A7D-8ED8-D6755555A993> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x110e1d000 - 0x111077ffd com.apple.security (7.0 - 55471.14.4) <1D5DA20E-DB48-3E1D-9BF5-BAA694192B25> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x1111c1000 - 0x1111c2fff liblangid.dylib (117) <9546E641-F730-3AB0-B3CD-E0E2FDD173D9> /usr/lib/liblangid.dylib
0x1111cc000 - 0x1111e7ff7 libCRFSuite.dylib (34) <FFAE75FA-C54E-398B-AA97-18164CD9789D> /usr/lib/libCRFSuite.dylib
0x1111f3000 - 0x11121cff7 libc++abi.dylib (49.1) <21A807D3-6732-3455-B77F-743E9F916DF0> /usr/lib/libc++abi.dylib
0x11122e000 - 0x111232ff7 libcache.dylib (62) <549DA205-700F-353D-A201-458D99964F9C> /usr/lib/system/libcache.dylib
0x11123d000 - 0x111247fff libcommonCrypto.dylib (60049) <D1ECE8B9-647E-3DE0-8AC9-B972E68E822C> /usr/lib/system/libcommonCrypto.dylib
0x11125b000 - 0x111262fff libcompiler_rt.dylib (35) <2A77D859-E2F7-3769-BCAC-F6971A7CAF7A> /usr/lib/system/libcompiler_rt.dylib
0x111271000 - 0x111278ff3 libcopyfile.dylib (103) <97D54BBE-C3B0-32CB-BB28-11006DEFD110> /usr/lib/system/libcopyfile.dylib
0x111281000 - 0x1112cffff libcorecrypto.dylib (161.1) <F3973C28-14B6-3006-BB2B-00DD7F09ABC7> /usr/lib/system/libcorecrypto.dylib
0x1112e7000 - 0x111301fff libdispatch.dylib (339.92.1) <C4E4A18D-3C3B-3C9C-8709-A4270D998DE7> /usr/lib/system/libdispatch.dylib
0x111322000 - 0x111325ff7 libdyld.dylib (239.4) <7C9EC3B7-DDE3-33FF-953F-4067C743951D> /usr/lib/system/libdyld.dylib
0x11132e000 - 0x11132eff7 libkeymgr.dylib (28) <CF815A65-3F2D-39D3-A58A-163574C43B12> /usr/lib/system/libkeymgr.dylib
0x111335000 - 0x11133cff8 liblaunch.dylib (842.90.1) <38D1AB2C-A476-385F-8EA8-7AB604CA1F89> /usr/lib/system/liblaunch.dylib
0x11134a000 - 0x11134ffff libmacho.dylib (845) <22EA37A3-5E09-3ABB-AA77-48EFF64090A5> /usr/lib/system/libmacho.dylib
0x111357000 - 0x111359ff7 libquarantine.dylib (71) <D8D3C33F-0328-3894-8898-D9766F888FE4> /usr/lib/system/libquarantine.dylib
0x111365000 - 0x111366ffb libremovefile.dylib (33) <EE47FD18-9E33-34C9-869F-0B91A5277C3F> /usr/lib/system/libremovefile.dylib
0x111372000 - 0x111383ff7 libsystem_asl.dylib (217.1.4) <BA3FA877-F584-342D-8DEE-4B548B8B7233> /usr/lib/system/libsystem_asl.dylib
0x11138d000 - 0x11138eff7 libsystem_blocks.dylib (63) <FB856CD1-2AEA-3907-8E9B-1E54B6827F82> /usr/lib/system/libsystem_blocks.dylib
0x111393000 - 0x11141cff7 libsystem_c.dylib (997.90.3) <6FD3A400-4BB2-3B95-B90C-BE6E9D0D78FA> /usr/lib/system/libsystem_c.dylib
0x111449000 - 0x11144bff3 libsystem_configuration.dylib (596.15) <4998CB6A-9D54-390A-9F57-5D1AC53C135C> /usr/lib/system/libsystem_configuration.dylib
0x111451000 - 0x111459fff libsystem_dnssd.dylib (522.90.2) <A0B7CF19-D9F2-33D4-8107-A62184C9066E> /usr/lib/system/libsystem_dnssd.dylib
0x111467000 - 0x11148effb libsystem_info.dylib (449.1.3) <6ABA5280-78A6-3BCE-B28C-8080CE5CDFF9> /usr/lib/system/libsystem_info.dylib
0x1114ab000 - 0x1114c7ff7 libsystem_kernel.dylib (2422.100.13) <498AEBD7-4194-3CF2-AA16-D5D03FFBD8C0> /usr/lib/system/libsystem_kernel.dylib
0x1114ed000 - 0x11151cfd2 libsystem_m.dylib (3047.16) <9937893C-3E60-3B35-B395-7CAF6F2B4C77> /usr/lib/system/libsystem_m.dylib
0x111528000 - 0x111543ff7 libsystem_malloc.dylib (23.10.1) <A695B4E4-38E9-332E-A772-29D31E3F1385> /usr/lib/system/libsystem_malloc.dylib
0x11154e000 - 0x111575ff7 libsystem_network.dylib (241.3) <ABD26C2E-C3C0-329B-AB7A-D4942783872E> /usr/lib/system/libsystem_network.dylib
0x111591000 - 0x11159aff3 libsystem_notify.dylib (121) <E9131A5B-EBFA-341F-BE7B-2084426F5435> /usr/lib/system/libsystem_notify.dylib
0x1115a8000 - 0x1115aeff7 libsystem_platform.dylib (24.90.1) <3C3D3DA8-32B9-3243-98EC-D89B9A1670B3> /usr/lib/system/libsystem_platform.dylib
0x1115c5000 - 0x1115ccff7 libsystem_pthread.dylib (53.1.4) <9D0EBF77-A6ED-3D51-9214-1DB9E8731900> /usr/lib/system/libsystem_pthread.dylib
0x1115dc000 - 0x1115ddff7 libsystem_sandbox.dylib (278.11) <B46E4040-A8C6-3EBC-91F8-F1CB01106614> /usr/lib/system/libsystem_sandbox.dylib
0x1115e4000 - 0x1115e8ff7 libsystem_stats.dylib (93.90.3) <4E51D5B0-92A0-3D0D-B90E-495A1ED3E391> /usr/lib/system/libsystem_stats.dylib
0x1115f5000 - 0x1115f6fff libunc.dylib (28) <A7E7B983-D29D-355A-BD95-43189161B663> /usr/lib/system/libunc.dylib
0x1115fe000 - 0x111603ff7 libunwind.dylib (35.3) <78DCC358-2FC1-302E-B395-0155B47CB547> /usr/lib/system/libunwind.dylib
0x11160b000 - 0x11162ffff libxpc.dylib (300.90.2) <AB40CD57-F454-3FD4-B415-63B3C0D5C624> /usr/lib/system/libxpc.dylib
0x111652000 - 0x111662fff libbsm.0.dylib (33) <2CAC00A2-1352-302A-88FA-C567D4D69179> /usr/lib/libbsm.0.dylib
0x111672000 - 0x11175cfff libsqlite3.dylib (158) <00269BF9-43BE-39E0-9C85-24585B9923C8> /usr/lib/libsqlite3.dylib
0x111779000 - 0x111786ff7 libxar.1.dylib (202) <5572AA71-E98D-3FE1-9402-BB4A84E0E71E> /usr/lib/libxar.1.dylib
0x11178e000 - 0x111792fff libpam.2.dylib (20) <A63D4DA2-06A4-3FB8-AC3F-BDD69694EE5E> /usr/lib/libpam.2.dylib
0x111798000 - 0x111798ffd libOpenScriptingUtil.dylib (157) <19F0E769-0989-3062-9AFB-8976E90E9759> /usr/lib/libOpenScriptingUtil.dylib
0x1117a3000 - 0x111a8dfff com.apple.CoreServices.CarbonCore (1077.17 - 1077.17) <3A2E92FD-DEE2-3D45-9619-11500801A61C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x111b0f000 - 0x111b9fff7 com.apple.Metadata (10.7.0 - 800.28) <E85AEB1B-CB17-38BC-B5C6-AAB50B47AF05> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x111c0a000 - 0x111c81fff com.apple.CoreServices.OSServices (600.4 - 600.4) <C63562F5-6DF5-3EE9-8897-FF61A44C8251> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x111d27000 - 0x111d94fff com.apple.SearchKit (1.4.0 - 1.4.0) <200B1199-785F-35DD-BCA7-B7C1F57DABC3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x111ddb000 - 0x111e36ffb com.apple.AE (665.5 - 665.5) <4E199B35-AC23-374C-80F1-DC26E5389B8F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x111e66000 - 0x111f2ffff com.apple.LaunchServices (572.26 - 572.26) <EF8A4A15-0861-35C5-9744-5E1BC5C26DD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x111fa5000 - 0x111fcefff com.apple.DictionaryServices (1.2 - 208) <EFE0AFF6-40DA-3417-B835-0C0F9D337F19> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x111ff3000 - 0x111ffafff com.apple.NetFS (6.0 - 4.0) <742B4B38-722A-3D3A-BEF1-0E294251D0C1> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x112008000 - 0x112013fff libkxld.dylib (2422.100.13) <67D079F8-6C48-3F42-9FBE-26F1ADA03DC4> /usr/lib/system/libkxld.dylib
0x112019000 - 0x112024ff7 com.apple.NetAuth (5.0 - 5.0) <C811E662-9EC3-3B74-808A-A75D624F326B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x112030000 - 0x112094fff com.apple.datadetectorscore (5.0 - 354.4) <37093186-6019-3071-8D67-F3EF429F8F08> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x1120d3000 - 0x1120d6fff com.apple.TCC (1.0 - 1) <EDAF25B2-A450-3E6C-932C-A994952C385D> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x1120e4000 - 0x1120fbff7 com.apple.CFOpenDirectory (10.9 - 173.90.1) <EBC0A1F2-9054-3D39-99AE-A3F655E55D6A> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x112120000 - 0x11212aff7 com.apple.bsd.ServiceManagement (2.0 - 2.0) <2128B3D1-4C78-3E12-A3B6-183CB192DA45> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x112135000 - 0x11215dffb libxslt.1.dylib (13) <C9794936-633C-3F0C-9E71-30190B9B41C1> /usr/lib/libxslt.1.dylib
0x11216d000 - 0x112171fff com.apple.CommonPanels (1.2.6 - 96) <8D58D10E-FBDB-3FB1-9812-4B08A4D19BE0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x11217d000 - 0x112180fff com.apple.help (1.3.3 - 46) <476C42CF-0A56-3515-B52D-F3170C4C0F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x11218d000 - 0x112437ff5 com.apple.HIToolbox (2.1.1 - 698) <A388E773-AE7B-3FD1-8662-A98E6E24EA16> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x112590000 - 0x1125a2fff com.apple.ImageCapture (9.0 - 9.0) <87B165A5-683E-36A2-A7C6-2FF7C80FD5C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x1125bd000 - 0x112649ff7 com.apple.ink.framework (10.9 - 207) <A14DB245-D0C3-3876-BAD8-CCB76B5A609B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x112683000 - 0x11269bff7 com.apple.openscripting (1.4 - 157) <B3B037D7-1019-31E6-9D17-08E699AF3701> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x1126b4000 - 0x1126b5ff7 com.apple.print.framework.Print (9.0 - 260) <6065DA3F-7533-3E81-8162-B1D1BED81D54> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x1126be000 - 0x1126c0ff7 com.apple.securityhi (9.0 - 55005) <18C42525-688C-3D47-B9C9-1E0F8F58FA64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x1126c7000 - 0x1126cfff7 com.apple.speech.recognition.framework (4.2.4 - 4.2.4) <E18D6C0E-890A-3709-9D4D-6FDE7D305CE7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x1126d9000 - 0x112ff8f43 com.apple.CoreGraphics (1.600.0 - 599.23.13) <3A1952C7-1D67-3DEC-A5AB-5399FF4F2A92> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x113126000 - 0x1131e8ff5 com.apple.CoreText (367.20 - 367.20) <B80D086D-93A9-3C35-860E-9C3FDD027F3B> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x11325c000 - 0x113362ff7 com.apple.ImageIO.framework (3.3.0 - 1043) <C4ADE5B1-A540-34E1-A043-118185489C9D> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x1133d0000 - 0x11343fff1 com.apple.ApplicationServices.ATS (360 - 363.3) <546E89D9-2AE7-3111-B2B8-2366650D22F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x11346c000 - 0x1134f5fff com.apple.ColorSync (4.9.0 - 4.9.0) <CAACFD0B-BDA8-3C23-9F6D-7062E09F509C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x11353c000 - 0x113581ff6 com.apple.HIServices (1.23 - 468) <5970AF5C-F5BD-3B6A-97C9-95B2CA98D71D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x1135ba000 - 0x1135c9ff8 com.apple.LangAnalysis (1.7.0 - 1.7.0) <15736125-5279-32FC-928E-8AE5EA6A6271> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x1135db000 - 0x113628ff2 com.apple.print.framework.PrintCore (9.0 - 428) <8D8253E3-302F-3DB2-9C5C-572CB974E8B3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x113656000 - 0x11368fff7 com.apple.QD (3.50 - 298) <BFA1E421-7ADF-3DA1-B7F0-100DF2E7E752> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x1136ae000 - 0x1136b7fff com.apple.speech.synthesis.framework (4.7.1 - 4.7.1) <383FB557-E88E-3239-82B8-15F9F885B702> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x1136ce000 - 0x1136d1ffc com.apple.IOSurface (91.1 - 91.1) <D00EEB0C-8AA8-3986-90C1-C97B2486E8FA> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x1136da000 - 0x1139aefc7 com.apple.vImage (7.0 - 7.0) <209BCF35-1D1E-37B7-BC14-D481C1047922> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x1139f1000 - 0x1139f1fff com.apple.Accelerate.vecLib (3.9 - vecLib 3.9) <F8D0CC77-98AC-3B58-9FE6-0C25421827B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x1139fa000 - 0x113ac5fff libvDSP.dylib (423.32) <3BF732BE-DDE0-38EB-8C54-E4E3C64F77A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x113ad7000 - 0x113b87ff7 libvMisc.dylib (423.32) <049C0735-1808-39B9-943F-76CB8021744F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x113b97000 - 0x113f78ffe libLAPACK.dylib (1094.5) <7E7A9B8D-1638-3914-BAE0-663B69865986> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x113fe1000 - 0x11414fff7 libBLAS.dylib (1094.5) <DE93A590-5FA5-32A2-A16C-5D7D7361769F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x11417f000 - 0x11426efff libFontParser.dylib (111.1) <835A8253-6AB9-3AAB-9CBF-171440DEC486> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x1142e9000 - 0x114330fff libFontRegistry.dylib (127) <401FA61F-4276-3296-9BFF-EC6EA7D7EDDE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x11435a000 - 0x11437eff7 libJPEG.dylib (1043) <25723F3F-48A6-3AC5-A7A3-58E418FEBF3F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x11438a000 - 0x1143e3fff libTIFF.dylib (1043) <D7CAE68F-6087-3B40-9CB8-EC6DB47BF877> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x1143f5000 - 0x114410ff7 libPng.dylib (1043) <23D2DAB7-C9A9-392F-989A-871E89E7751D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x11441b000 - 0x11441fff7 libGIF.dylib (1043) <AF0FE71A-27AB-31E0-8CEA-BC0BF2091FA8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x114428000 - 0x114516fff libJP2.dylib (1043) <C4031D64-6C57-3FB4-9D87-874D387381DB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x114545000 - 0x114547fff libRadiance.dylib (1043) <9813995C-DEAA-3992-8DF8-320E4E4E288B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x11454f000 - 0x114596ff7 libcups.2.dylib (372.4) <36EA4350-43B4-3A5C-9904-10685BFDA7D4> /usr/lib/libcups.2.dylib
0x1145ae000 - 0x1145c7ff7 com.apple.Kerberos (3.0 - 1) <26A389F3-8820-30EE-8997-F0E8EFD8BB4E> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x1145e7000 - 0x114616ff9 com.apple.GSS (4.0 - 2.0) <44E914BE-B0D0-3E05-9451-CA9E539AFA52> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x114635000 - 0x114651fff libresolv.9.dylib (54) <11C2C826-F1C6-39C6-B4E8-6E0C41D4FA95> /usr/lib/libresolv.9.dylib
0x114663000 - 0x1146c8ffb com.apple.Heimdal (4.0 - 2.0) <F34D6627-9F80-3823-8B57-DB629307DF87> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x1146f4000 - 0x1146f5fff com.apple.TrustEvaluationAgent (2.0 - 25) <334A82F4-4AE4-3719-A511-86D0B0723E2B> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x1146fa000 - 0x1146feff7 libheimdal-asn1.dylib (323.92.1) <CAE21FFF-5763-399C-B7C5-EEBFFEEF2242> /usr/lib/libheimdal-asn1.dylib
0x114706000 - 0x114712ff7 com.apple.OpenDirectory (10.9 - 173.90.1) <256C265B-7FA6-326D-9F60-18DADF5F3A0E> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x11472a000 - 0x114733ffd com.apple.CommonAuth (4.0 - 2.0) <32BA436F-6319-3A0B-B5D2-2EB75FF36B5B> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x11473d000 - 0x1147b0fff com.apple.securityfoundation (6.0 - 55122.1) <D5AA4461-7406-3054-875D-0EDA3A6030EA> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x1147f0000 - 0x1148d4fff com.apple.coreui (2.1 - 231) <432DB40C-6B7E-39C8-9FB5-B95917930056> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x114998000 - 0x114b34ff3 com.apple.QuartzCore (1.8 - 332.3) <72003E51-1287-395B-BCBC-331597D45C5E> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x114c10000 - 0x114d40ff7 com.apple.desktopservices (1.8.3 - 1.8.3) <225BEC20-F8E0-3F22-9560-890A1A5B9050> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x114dc6000 - 0x114dd8ff7 com.apple.MultitouchSupport.framework (245.13 - 245.13) <E51DE5CA-9859-3C13-A24F-37EF4385C1D6> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x114dee000 - 0x114e06ff7 com.apple.GenerationalStorage (2.0 - 160.3) <64749B08-0212-3AC8-9B49-73D662B09304> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x114e1d000 - 0x114e58fff com.apple.bom (14.0 - 193.1) <EF24A562-6D3C-379E-8B9B-FAE0E4A0EF7C> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x114e6e000 - 0x11513effc com.apple.CoreImage (9.2.8) <1509987F-5671-3AE3-91C7-18E952ED90C7> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x11523a000 - 0x11528dfff com.apple.ScalableUserInterface (1.0 - 1) <82D27BF0-3522-3142-BACE-F9F7A5CE6140> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x1152b7000 - 0x1152f6fff libGLU.dylib (9.6.1) <AE032555-3E2F-3DBF-A26D-EA4576061605> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x115309000 - 0x115311ffc libGFXShared.dylib (9.6.1) <25BBF325-AC57-3BAA-9427-2D14CC243AE6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x11531d000 - 0x115328fff libGL.dylib (9.6.1) <4B65BF9F-F34A-3CD1-94E8-DB26DAA0A59D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x115342000 - 0x115380ff7 libGLImage.dylib (9.6.1) <5E02B38C-9F36-39BE-8746-724F0D8BBFC0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x115389000 - 0x11538bfff libCVMSPluginSupport.dylib (9.6.1) <FB37F4C4-1E84-3349-BB03-92CA0A5F6837> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x115396000 - 0x115399fff libCoreVMClient.dylib (58.1) <EBC36C69-C896-3C3D-8589-3E9023E7E56F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x11539f000 - 0x1157d2ffb com.apple.vision.FaceCore (3.0.0 - 3.0.0) <374EE20F-272C-3409-8558-8158621147CD> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x1159f0000 - 0x1159faff7 com.apple.CrashReporterSupport (10.9 - 539) <B25A09EC-A021-32EC-86F8-05B4837E0EDE> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x115a0d000 - 0x115a5bff7 com.apple.opencl (2.3.59 - 2.3.59) <044485A4-A50C-34CE-A1F9-35A50CC68313> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x115a7a000 - 0x115a86ff3 com.apple.AppleFSCompression (56 - 1.0) <4A122488-B180-32E1-904F-0AB80F2BF011> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x115a91000 - 0x115aaaff7 com.apple.Ubiquity (1.3 - 289) <664F5B33-708D-33E9-81E1-C45CBE9AAB6E> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x115ac4000 - 0x115ad1fff com.apple.Sharing (132.2 - 132.2) <F983394A-226D-3244-B511-FA51FDB6ADDA> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x115ae8000 - 0x115b18fff com.apple.IconServices (25 - 25.17) <B5AA96F2-F205-32DD-AC76-E4C04FF24B72> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x115b48000 - 0x115b6dff7 com.apple.ChunkingLibrary (2.0 - 155.1) <8BE63F6D-BD20-32A5-876B-02F5C6F5F61E> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x115b7f000 - 0x115dc7ff7 com.apple.CoreData (107 - 481.3) <E78734AA-E3D0-33CB-A014-620BBCAB2E96> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x115ef1000 - 0x115f29ff7 com.apple.RemoteViewServices (2.0 - 94) <4B72D2C5-E25C-3C40-A3F7-FB74843A0D3C> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x115f67000 - 0x115fa8fff com.apple.PerformanceAnalysis (1.47 - 47) <7B73DFF4-75DB-3403-80D2-0F3FE48764C3> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x1167fd000 - 0x1168c1ff7 com.apple.backup.framework (1.5.3 - 1.5.3) <088FEDED-BF5C-33F4-A51A-646C8149BDAA> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x11694d000 - 0x1169cefff com.apple.CoreSymbolication (3.0.1 - 141.0.5) <20E484C4-9F0E-3DF6-BB27-D509859FF57A> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x116a20000 - 0x116a78ff7 com.apple.Symbolication (1.4 - 129.0.2) <B1F008C4-184D-36A2-922F-4A67A075D512> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x116ac4000 - 0x116af3fff com.apple.DebugSymbols (106 - 106) <2C3BEDCB-376B-31EE-B8BF-1872C010A630> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x116b12000 - 0x116b29ffa libAVFAudio.dylib (32.2) <B1AA352E-F4F6-3E69-B2B4-EACE9448405C> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
0x116b3b000 - 0x116e71fff com.apple.MediaToolbox (1.0 - 1273.54) <E11683F7-BB60-37EB-98B6-BD519D93CB30> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x116f23000 - 0x117371fef com.apple.VideoToolbox (1.0 - 1273.54) <4699BB55-7387-3981-9217-869215F00CA9> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x1173d3000 - 0x11741fffe com.apple.CoreMediaIO (407.0 - 4561) <040A98E4-F480-315B-BCEE-C18AF686492C> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x11744d000 - 0x117463fff com.apple.CoreMediaAuthoring (2.2 - 947) <F1886A05-1C29-3F88-88C0-4A1013530AD1> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x11747c000 - 0x1175abfef com.apple.MediaControlSender (2.0 - 200.34.4) <FC24EC8D-2E46-3F76-AF63-749F30857B96> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender
0x1175e5000 - 0x117614ff7 com.apple.CoreAVCHD (5.7.0 - 5700.4.3) <884652F6-C516-3064-ABB7-229602832ADD> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x117620000 - 0x117625ff7 com.apple.MediaAccessibility (1.0 - 43) <F9807FF1-5C4B-37EF-9DB5-E226D3997533> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x117633000 - 0x117635fff com.apple.Mangrove (1.0 - 1) <A2576E83-FAF4-3014-BEF5-1572F0C2963B> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x11763b000 - 0x117a12fef com.apple.CoreAUC (6.25.00 - 6.25.00) <2D7DC96C-BA83-3220-A03F-C790D50A23D8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x117a20000 - 0x117a3dff7 com.apple.framework.Apple80211 (9.3.2 - 932.59) <DA61BF63-978E-342D-8F7F-83D0169A7F48> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x117a50000 - 0x117a58ff7 com.apple.AppleSRP (5.0 - 1) <ABC7F088-1FD5-3768-B9F3-847F355E90B3> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x117a60000 - 0x117ac7ff7 com.apple.CoreUtils (2.0 - 200.34.4) <E53B97FE-E067-33F6-A9C1-D4EC2A20FB9F> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x117af7000 - 0x117b56fff com.apple.framework.CoreWLAN (4.3.3 - 433.48) <7F86A7C3-7B7D-3CD7-9758-CA74FB4DE2CC> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x117b98000 - 0x117bc2ff7 libpcap.A.dylib (42) <91D3FF51-D6FE-3C05-98C9-1182E0EC3D58> /usr/lib/libpcap.A.dylib
0x117bd1000 - 0x117c37fff com.apple.framework.CoreWiFi (2.0 - 200.21.1) <0684ECE0-3666-3E22-859A-177C2F336A59> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x117c9c000 - 0x117ce9fff com.apple.AppleVAFramework (5.0.27 - 5.0.27) <608D91BD-9D88-3FAB-9A06-24C1DAEA092D> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x117cf8000 - 0x117cfeff7 com.apple.XPCService (2.0 - 1) <D761CEC3-19C7-3A56-A4F5-220E60891D97> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x117d0d000 - 0x117d17ff7 com.apple.AppSandbox (3.0 - 1) <9F27DC25-C566-3AEF-92D3-DCFE7836916D> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x117d23000 - 0x117d4dff7 libsandbox.1.dylib (278.11) <BD3D8652-8871-36DB-A27D-3BE4F18428B4> /usr/lib/libsandbox.1.dylib
0x117d5a000 - 0x117d6dff7 com.apple.AppContainer (3.0 - 1) <BD342039-430E-39FE-BC2D-8F97B557548E> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x117d82000 - 0x117d84fff com.apple.SecCodeWrapper (3.0 - 1) <DE7CA981-2B8B-34AC-845D-06D5C8F10441> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x117d8d000 - 0x117d95fff libMatch.1.dylib (19) <021293AB-407D-309A-87F5-8E782F46753E> /usr/lib/libMatch.1.dylib
0x117d9b000 - 0x117dd0ffc com.apple.LDAPFramework (2.4.28 - 194.5) <4ADD0595-25B9-3F09-897E-3FB790AD2C5A> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x117de4000 - 0x117df4ffb libsasl2.2.dylib (170) <C8E25710-68B6-368A-BF3E-48EC7273177B> /usr/lib/libsasl2.2.dylib
0x117dfb000 - 0x117e13fff libexpat.1.dylib (12) <97F4A9A7-CB3E-3BBF-9314-4997FC770E52> /usr/lib/libexpat.1.dylib
0x117e1e000 - 0x118195ff6 com.apple.JavaScriptCore (9537 - 9537.75.12) <C3A7612F-34CC-3547-B01C-522D255B69ED> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x118290000 - 0x1190e2ffb com.apple.WebCore (9537 - 9537.75.14) <B43801D5-1BD9-3385-B028-39E2A346D064> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x119ddb000 - 0x119de3ff3 libCGCMS.A.dylib (599.23.13) <59F7AEED-90EB-35C2-85A6-5BC44CC9B3FA> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
0x11b45e000 - 0x11b48afff com.apple.CoreServicesInternal (184.9 - 184.9) <4DEA54F9-81D6-3EDB-AA3C-1F9C497B3379> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/CoreServicesInternal
0x11b4fc000 - 0x11b509ff4 com.apple.Librarian (1.2 - 1) <6527682F-BFBD-3E92-B3EA-BDBFB7F6E624> /System/Library/PrivateFrameworks/Librarian.framework/Librarian
0x11b595000 - 0x11b595feb +cl_kernels (???) <C0F03F93-D3B0-47EE-BF0F-C49D85A20740> cl_kernels
0x11b680000 - 0x11b683ffa libCGXType.A.dylib (599.23.13) <E459DD26-592F-3DBD-8C47-B342ECE8FFD3> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x11b68b000 - 0x11b68fffd com.apple.audio.AppleHDAHALPlugIn (2.6.1 - 2.6.1f2) <E5405175-7735-3F30-97ED-F44645033DC7> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x11c8ab000 - 0x11c8d3ffb libRIP.A.dylib (599.23.13) <FFE421E6-CB15-3F9D-ADF4-679E26B09892> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x11de70000 - 0x11de74fff com.apple.IOAccelerator (98.20 - 98.20) <D62AE4C8-E4BD-3924-826D-7D8D07F9EDEB> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x11de7c000 - 0x11de87fff libGPUSupportMercury.dylib (9.6.1) <A34D5C51-28E0-398A-881D-552B47D2DD3C> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x11e505000 - 0x11e511ff7 com.apple.HelpData (2.1.4 - 90) <3EBCB45E-2434-346B-89C0-169CE1E35E68> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x11e9d2000 - 0x11e9f2fff +com.numark.usb2.hal (2.0.2) <4416318B-13E6-E087-745A-EE8E073B4FDE> /Library/Audio/Plug-Ins/HAL/NumarkUSB2AudioHAL.plugin/Contents/MacOS/NumarkUSB2AudioHAL
0x11ea32000 - 0x11ea3bff7 libcldcpuengine.dylib (2.3.58) <E3A84FEC-4060-39C2-A469-159A443D2B6D> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x11ea41000 - 0x11ea43fff com.apple.EFILogin (2.0 - 2) <FC03D854-FC1F-3A40-ACDD-CFFE52B07B4D> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x11ea49000 - 0x11ea4bffb libutil.dylib (34) <DAC4A6CF-A1BB-3874-9569-A919316D30E8> /usr/lib/libutil.dylib
0x120141000 - 0x120141ffd +cl_kernels (???) <0699FBAA-D3C4-4BDA-AF84-26CAA4585776> cl_kernels
0x120150000 - 0x1202f0ff7 GLEngine (9.6.1) <28300FBD-E3B2-35D2-BB54-77DCE62FC371> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x12032c000 - 0x120492fff libGLProgrammability.dylib (9.6.1) <07700B99-8542-32D7-BB96-29472EFE75EF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x1208b6000 - 0x1208dffff GLRendererFloat (9.6.1) <23A2C705-F932-335D-B27B-565A30333460> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x1208e8000 - 0x1209b9ff1 com.apple.DiskImagesFramework (10.9 - 371.1) <B26C8237-52E0-3E93-A2E2-147B57B3292E> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x120a19000 - 0x120ad1ff7 com.apple.DiscRecording (8.0 - 8000.4.6) <FCBB5558-A702-3658-AEE4-7D129AFBF350> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x120b39000 - 0x120b43ff7 libcsfde.dylib (380) <A5CF6F85-0537-399F-968B-1536B1235E65> /usr/lib/libcsfde.dylib
0x120b4e000 - 0x120b7ffff com.apple.MediaKit (15 - 709) <689833FD-088F-39BE-84CC-7E88173E9FC3> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x120b91000 - 0x120c1cfff libCoreStorage.dylib (380) <DE9B3F8C-045C-3010-9A25-C8CD72
User ID: 504
Report Version: 11
Crashed Thread: 15
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15 Crashed:
Thread 16:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Logical CPU: 0
Trap Number: 14
Binary Images:
geposted Wed 11 Jun 14 @ 4:01 pm
