Topic: auto gain
Auto gain? In Ver.7 Auto gain was flawless, always adjusting to perfect play back.. I set AUTO GAIN and I still have to adjust the volume output on mY VMS4.1.
REST PITCH does not reset when track is loaded, I have set my setting to do so..
geposted Thu 15 May 14 @ 1:39 am
djjbPRO InfinityMember since 2004
Well...when automix is on, the autogain is not working.
So far I know you have to load a track complete before the gain will set to 0.0. If you press play before that, the gain will not change.
geposted Sat 17 May 14 @ 12:16 am
Backing this up, auto gain is not right in automix at all.
geposted Sat 17 May 14 @ 3:38 am
This is one problem i dont have, Ive rescanned my whole library in VDJ8. I do change me zerodb to .5 and auto&remember. So if its gain is to high I would decrease that setting.
geposted Sat 17 May 14 @ 7:41 am
