OK i have it working well and I love it but....I cannot have milkdrop running and then fade to a video. When I fade to video milkdrop just keeps on playing. The same thing is happening weather I use miilkdrop as a visualization or as a video effect. Is there a way around this?
geposted Fri 16 May 14 @ 12:33 am
It should be in the master effect panel. You have it selected in config/video/ videoaudioonlyVisualisation?
geposted Fri 16 May 14 @ 12:42 am
THANK YOU!! I was starting it using "Video FX Select" under the Video tab. I never thought to use the master....thank you again!
geposted Fri 16 May 14 @ 1:14 am
Good to see you got it figured out, gonna use it myself live tomorrow for the first time (yes I have a backup). I just love what Milkdrop has and it will be a refreshing change!!
geposted Fri 16 May 14 @ 1:42 am
Please try with ContentUnlimited. I had an issue earlier this evening. It stop working and I had to restart. There does seem to be an issue turning it off. I tried again with the same files, but all seems well.
geposted Fri 16 May 14 @ 3:13 am
