Hi there,
I'm using the Vestax VCI400 and just installed the actual drivers on my computer to test the new VDJ.
The software recognized immediately Vestax VCI-400 in the soundcards, but with a Wasapi driver.
![](/image/97681/135872/Image 1.jpg)
As soon as I try to change this (as this driver doesn't work fine) to VCI-400 (Asio), the configuration jumps to either "Internal soundcards" or "2 soundcards" (sometimes to the one or the other).
![](/image/5399/135873/Image 2.jpg)
Please take care of this problem because I can't use v8 if I can't choose the correct soundcard.
Ty
Paul
Ty
Paul
geposted Sun 18 May 14 @ 10:26 am
same here
reported in beta forum
geposted Sun 18 May 14 @ 10:39 am
Braenzu wrote :
same here
And here.
geposted Sun 18 May 14 @ 11:07 am
Vestax had unfortunately changed the drivername in the latest updated version (which btw is titled to work with Win8)
Anyways, we have updated the default files to use the new ASIO name. If for some reason someone has the old version, it will fall to Wasapi of course if click on the VCI button on the top, but could choose the driver from the list too and save his Audio Setup as a profile.
Fixed in builds ending at .645
geposted Sun 18 May 14 @ 1:34 pm
@ djdad
Is there a dedicated mapper for the VCI-400DJ? Because some buttons/sliders printing and the firmware are different from the classic 400.
If you need any help I have all Vestax device here ;)
geposted Sun 18 May 14 @ 1:42 pm
Thanks Babis...all VCI 400 DJ´s will appreciate that.
So Braenzu was right, cause he suspected a "name issue" right from the beginning...
geposted Sun 18 May 14 @ 2:17 pm
thanks Babis...you are my hero!!!
one who understands me :o)
geposted Sun 18 May 14 @ 2:21 pm
It seems that the VCI400 works fine on my MacMini (2011)..
Now i'll test it on my "Live Mac" MacBook Pro 2012…
geposted Wed 21 May 14 @ 5:59 pm
okay with my MacBook Pro 2012 and Mountain Lion i can't use the VCI400.
Virtual DJ found the Controller as Source/Soundcard but in the Audiosettings there is No Vestax availible to choose as the Card... Only Internal Soundcard, Two Soundcards and Stereo to Mono split is showing up... anyone else the same prob?
geposted Thu 22 May 14 @ 10:01 am
