Hello,
Could anybody tell me why some of my visuals don't work whithin VDJ 8 ?
I made a new shortcut called "Clipbank"
When I drag a video into it, the video will play normally.
But when I load my visuals, the video will not play.
The visuals always worked. These are mpg files and the music video are vob files.
But also with a video converter to vob, it didn't work.
Anybody familiar with this problem?
By the way, the new VDJ 8 is great !
geposted Tue 20 May 14 @ 11:20 am
When you drop the sample into the bank - try opening the SamplerEditor for that sample and make sure it is set up correctly for loop or drop etc.
Save any changes you need to do then try again? Any better?
geposted Tue 20 May 14 @ 11:22 am
Thanks djtouchdan !
That was the problem.
When used the sample editor, click on "video" and save, the problem is solved.
Thanks for the very quick reply.
geposted Tue 20 May 14 @ 11:36 am
