Is it going to be possible to have the person who made the syphon plugins for vdj make them compatible with version 8 as on mac i feed visuals through syphon too
geposted Wed 21 May 14 @ 12:13 pm
I believe it is being done. No timescales though.
geposted Wed 21 May 14 @ 12:26 pm
Yes, they will be available very shortly (PC and Mac versions!).
geposted Wed 21 May 14 @ 1:39 pm
Killin em on both platforms!!
I gotta say the fact that I can now syphon on a PC is the absolute shit!!! Y'all will not be disappointed!!
geposted Wed 21 May 14 @ 2:10 pm
Between VDJ and what?
I use GrandVJ and I'm not sure if it can do the job.
geposted Wed 21 May 14 @ 2:12 pm
I have a feeling it may work ;-)
geposted Wed 21 May 14 @ 2:46 pm
thanks you guys rule:)
geposted Wed 21 May 14 @ 3:07 pm
On PC, between VDJ and any application that supports FFGL plugins. There is also a 'webcam' driver that works in some applications too.
On Mac, between VDJ and any application that supports Syphon, in either direction.
geposted Wed 21 May 14 @ 3:24 pm
geposted Fri 23 May 14 @ 10:51 am
SBDJ, You are quite simply a legend :)
geposted Mon 26 May 14 @ 3:44 pm
VDJ to Resolume seems broken now........ Doesn't work on my machine anymore and the only thing that's changed is VDJ.
geposted Tue 24 Jun 14 @ 8:30 am
I haven't had much luck with Resolume installing on my machine so I can not confirm but can you describe broken? No communication? Locks up?
geposted Tue 24 Jun 14 @ 12:14 pm
Syphon is working here on 1845.
geposted Tue 24 Jun 14 @ 12:59 pm
works great.
Download syphon plugin for VDJ8 on VDJ site ( http://www.virtualdj.com/addons/16750/syphonserver8.html )
& put unzipped-file in:
/Volumes/..../USER/Documents/VirtualDJ/Plugins64/VideoEffect/SyphonServer8.bundle
Choose the effect via the Video Effect dropdown in VDJ 8 and click on the grey circle left of the name, which will then turn green, indicating VDJ 8 is acting as a Syphon server.
Then, you can of course pick up the signal in another Syphon-enabled client, like Syphon Recorder, Resolume Avenue, GrandVJ, VDMX, etc. (I have 'em all ;-))
Thanks to the VDJ team for this !
Syphon plugin for VDJ 7 also exists & works (that's a different file).
geposted Thu 03 Jul 14 @ 11:48 am
