- Fixed the settings buttons problem for MAC
- addition of the central white bar in the vertical scratchwave
- Correction of the central landmark rythmezone which does not appear in small resolutions
geposted Fri 30 May 14 @ 10:39 am
Good job. I will be follow you forever.●﹏●
geposted Fri 30 May 14 @ 1:06 pm
thanks ;-)
geposted Fri 30 May 14 @ 2:55 pm
The skin now sits perfectly on the Mac! Thanks for making that button location change!
geposted Tue 03 Jun 14 @ 10:42 am
Hello .... I am unable to view the above waweform in default mode!
geposted Tue 03 Jun 14 @ 11:35 am
amazing! I can see ther with any mode!
can you post a screen?
geposted Tue 03 Jun 14 @ 1:14 pm
here it :-(
geposted Wed 04 Jun 14 @ 11:33 am
it's really weird cause it works perfectly to me, and also with other users !
I updated the skin there two days, you have the latest version?
geposted Wed 04 Jun 14 @ 11:59 am
I downloaded it last night ... I do not understand why :-(
geposted Wed 04 Jun 14 @ 12:08 pm
hello Dodge
I just tested and I also have the same problem !
bonjour Dodge
Je viens de tester et j'ai également le même problème !
bonjour Dodge
geposted Wed 04 Jun 14 @ 4:45 pm
@dodge
You forgot to put the "os", line 866
you put : <button action="settings">
you must put : <button os="pc" action="settings">
and add new lines with : <button os="mac" action="settings">
juan
juan
geposted Wed 04 Jun 14 @ 6:33 pm
indeed I just downloaded the online version and I have the same worries!
I'll see what it is, probably a typing error ... sorry
@ Juan, this is not an oversight, it's voluntary. I made this change after RLove have told me about problems on mac, and it seems to be good for him.
[EDIT] Correction is online !
geposted Wed 04 Jun 14 @ 7:44 pm
Thank Dodge ...... great job! Thank you again! :-)
geposted Thu 05 Jun 14 @ 11:45 am
for the big browser you have forgotten to hide the informations when it's the normal browser (tooltip of all, i.e sidelist, cue, play, .....) when you put the mouse on the same zone
juan
juan
geposted Sat 07 Jun 14 @ 12:05 am
first i have to say nice skin but i notice the wave form are different color in different wave form modes here a pic of them
this is the first pic
and the second
and the second
geposted Fri 13 Jun 14 @ 10:37 am
you can select the color of the waveforms in option -> Slins -> ColoredWaveforms
Jmf, I don't anderstaknd what you would say...
geposted Fri 13 Jun 14 @ 4:24 pm
You need to panel everything else that would be under the big browser when its open as if you haven't the actions still work through the big browser.
Think that is what he is saying.
geposted Fri 13 Jun 14 @ 5:15 pm
I have not noticed a problem with the fullscreen browser ...
geposted Fri 13 Jun 14 @ 6:33 pm
@angelt99
You need to change the coloredwafeform, don't choose monochrome (config/options/skins/coloredwafeforms)
juan
juan
geposted Fri 13 Jun 14 @ 9:28 pm
jmf28 wrote :
@angelt99
juan
juan
ok thank u the only 1 that work that is the same color is ultra blue.but that will do.thanks
geposted Sat 14 Jun 14 @ 12:25 am
