This is exactly the same as on the Original VD8 skin : monochrome & per deck is 2 different colors and neutral, ultra blue & infra red is the same color
geposted Sat 14 Jun 14 @ 7:11 am
how do you change color in the browser?:-)
geposted Sun 15 Jun 14 @ 5:10 am
i believe what you want with "browser colors" are changed in the tags of the music files.
geposted Sun 15 Jun 14 @ 5:37 am
YES:-)
geposted Sun 15 Jun 14 @ 9:11 am
I really like this skin ..... and if I can ask 'can enable "smart play" just clicking with the "right" mouse?
geposted Sun 15 Jun 14 @ 9:19 am
since it looks like the default skin with colors changed try the dot next to the sync button with a left click :-)
oh and its by cue button on right side
geposted Sun 15 Jun 14 @ 9:20 am
you must set the "Play Smart" ..... I wanted to enable this feature with the right mouse button ... only temporarily without changing the settings of the deck would be very comfortable ....
geposted Sun 15 Jun 14 @ 9:24 am
you can put this script in a custom button down ? smart_play on : smart_play off
but I don't find a script to have a right clic temporary action...
but with the keyboard it's be possible with this script : down ? smart_play on : smart_play off
geposted Sun 15 Jun 14 @ 10:01 am
honestly, I do not know how this thing .... in the past there was a skin that had this feature ... but I do not know how to do it ....
geposted Mon 16 Jun 14 @ 7:42 am
this is very simple:
Settings -> Controlers -> select a key -> paste the script
geposted Mon 16 Jun 14 @ 10:21 am
I can not set this function on the right mouse button?
geposted Tue 17 Jun 14 @ 2:33 am
you want to assign this function permanently on the right clic or you want a button on the skin where you right click ?
Because assign a permanent function of the right click is to my knowledge not possible
geposted Tue 17 Jun 14 @ 6:21 am
Correct. Can only be added to a specific button
geposted Tue 17 Jun 14 @ 6:49 am
sin ... with virtual dj 7 could be done! .... thanks guys :-(
One other question .... can I add a button to jump to the beat of 4 ... 8 ...?
geposted Tue 17 Jun 14 @ 12:10 pm
here is the topic of VirtualDJ 8 Soft Gold Skin
please ask your questions in the dedicated topic
thanks
thanks
geposted Tue 17 Jun 14 @ 12:54 pm
any plans for a soft gold 4 decks??
thank you
thank you
geposted Mon 23 Jun 14 @ 4:14 pm
like many people I waiting for the wiki of the V8 script ;-)
geposted Mon 23 Jun 14 @ 6:27 pm
1+
geposted Tue 24 Jun 14 @ 2:27 am
Corrections :
With the help of my friend Jmf28 I could correct panels errors in the Full Browser page. Indeed, the panels of normal page were still active, and therefore there were problems sliding tracks to sidelist or Automix.
at the same time I added playback controls in Full Browser page
http://fr.virtualdj.com/addons/16744/VirtualDJ_8_Soft_Gold.html
geposted Thu 03 Jul 14 @ 11:36 am
Dodge57 wrote :
ok, I see.
To avoid having to change the whole skin, I decided to place the menu buttons in the same way for PC and Mac.
I chose the exact same workaround for my skin :)
geposted Thu 03 Jul 14 @ 1:28 pm
