Forum: Wishes and new features
Topic: Browser - Wishes & new features - Page: 17
No. not at present.
OT [ish]
kradcliffe wrote :
I don't agree with that. I paid $299 for software to do the job for me.
dangerous argument, you could as easily say I don't want to learn beating matching, song structure any other intrinsic part of the craft.
djing can be a long road with many directions to learn something new.
I paid for my satnav to direct me from a to b, but I put a bit of effort in to find a good sandwich shop along the route.
To get back to the topic of this thread I'd like to add my idea to this wishlist here:
In the browser you can get the position of the prelisten song with 'prelisten_pos'. But the range of the return value is 0..1. I'm looking for a function which returns the pelisten song position in "hh:mm:ss" format.
I tried something like format="`prelisten_pos & param_multiply get browsed_song length`" or something like that - but it doesn't work.
So this would be cool to have an option to format the position of the prelisten song to format hh:mm:ss
Hello Staff.
I would like to add show bitrate for audio from video file !!
As it is now, it only shows video bitrate from the video file and not the audio from the same file.
I have an idea which i know from data management systems: Show me the playlists (or folders, virtual folders, or history) in which playlists (or, or, or...) this song (file) is in use.
For example: I select the Song "AC/DC - Highway to hell" - right click - song is in use in... - list of playlists, folders, virtual folders, history.
Alternative: separate window opens which contains the list mentioned before.
I would love to see a feature allowing to add a song to one of existing playlist from context menu (rekordbox style).
music234 wrote :
........................ everybody should be able to copy and paste things like this on a custom-button.
Is it me, am I missing something? I can't paste the script posted above in the custom key editor. I'm using a boot camped MBP, can't paste on Mac or PC.
Strangely, I can copy and paste from another custom button.
***Edit***
Managed to do it in 2 chunks. Must be a character limit.
this is a simple one..
use , to separate between digits.. example: 112,648 files. for obvious reasons.
Auto-rating based on how many times a track is played
Ability to sort 2 or more columns. Like i click BPM and its sorted hold control/whatever it is on mac, then click key Columns and its sorted.
It's already sorting by the 2 last columns you clicked
option to auto fill in missing info from discogs and write to file.
bulk file operation.
I'd appreciate being able to expand/collapse folders with the left/right arrow keys.
+1
I propose to expand the function of the browser!
I'm very uncomfortable that the track from the playlist or from the folder itself in the built-in browser of the program can not be dragged anywhere (to another player, for example, to the desktop or player aimp), ie, from other players, the files are easily transferred to the deck, and vice versa no :(
Proposal 2:
Why do I edit the track tag only in a separate window?
It would be very cool when a track or a whole group of tracks (with one artist) could be edited straight in the browser! (Strike the stars of the rating, change the name, artist, genre of the track, etc.). After all, you agree, it takes a lot of time to edit the names and things in the track, because you constantly go to the editing window of ONE track ...
If my plea is heard, will be a HUGE advantage in this program. It is also visible that the guys of the developers have tried so hard, thanks to them!
#2 it is possible to edit several tracks tags all at once, shift+click, ctrl+click or even ctrl+shift+click to select several files and open the tag editor.
ability to add a windows folder to the sampler library as a sampler bank.
just drag and drop these folders from windows folder to the sampler folder to create sampler banks "drums" and "drums2" and "drums3" each containing songs from their respective windows folder.
e:\loops\drums
e:\loops\drums2
e:\loops\drums3
grenno wrote :
Set ratings in Browser
Instead of having to change the rating by opening the individual tag for each track, being able to set the track rating directly from the browser (similar to windows media player) would be an absolute game changer. Allowing you to set tracks as you play them. Or go through an entire folder in a fraction of the time.
Yes!, this is one of the most painful gaps in the current browser.
use the rate'n'colour plugin.
Or use a custom buttons with
browsed_song rating 5
browsed_song rating 4
browsed_song rating 3
etc.
37%
