another video fx shader that I think would be cool as an actual video fx, there's next to nothing as shader code
https://www.shadertoy.com/view/3d2BWc | view on shadertoy | copy link
geposted Mon 01 Jun 20 @ 6:23 pm
Hi & Good day to the VDJ developer team,
I wish for the camera able to area cropped instead of the current zoom.
The camera positioning is great.
Thank you for your kind attention.
geposted Mon 01 Jun 20 @ 7:54 pm
CANON EOS WEBCAM DRIVERS
I would like to make a request to the VDJ team.
Canon created a beta driver to unable some EOS camera to be used as webcam. It is called EOS Webcam Utility. Zoom, Google Meet, OBS recognize my EOS as a webcam, but not VDJ. Would it be possible to make this feature available?
See the link: https://1.shortstack.com/VChq6Z
Thank you
Thank you
geposted Tue 02 Jun 20 @ 8:06 pm
I'm not sure if this has ever been requested before, but I thought of it, and ISTM a really obvious useful thing to have...
When looking at video transitions in the addons area, there's an animated preview that shows what the effect does.
I think it would be really beneficial to have that preview visible in VDJ (on skins) when browsing video effects, so that the user can see what that effect is going to do. It doesn't need to be huge, just big enough to see what's happing.
At the moment it's just a list of names, with no way (AFAIK) of reviewing that video effect.
geposted Thu 04 Jun 20 @ 10:01 am
it would be great if you can bring back the animated logo like it used to be in VDJ7 :)
geposted Tue 07 Jul 20 @ 4:05 am
i want to toggle the comment field on and off similar to the text field
geposted Tue 13 Oct 20 @ 7:44 am
“add /(remove)to database” option in tag editor window and status , also when right click on cover of a loaded deck
geposted Thu 17 Dec 20 @ 11:35 pm
Greetings virtual dj team:
In the next updates I would like to see the following improvements in the camera section or create a new one as "master output mix", in which you will find everything that is in the camera plugin, plus a transition tab and in the sources; In addition to the cameras, you can select other sources such as the video window, the program window and any program or application open in the operating system.
geposted Sun 17 Jan 21 @ 4:47 pm
I would like to have
in Video FX > Master Video Effects > Overlays > Comment field output
geposted Wed 17 Mar 21 @ 11:02 am
Was possible some time ago using text overlay...
get_text "`get_loaded_song 'comment'`" & param_cast text & effect_string 'text' 2
But text in " effect_string 'text' 2 " was removed from 'text' plugin and replaced with preset
Please make it come back again, was useful for dynamic messages
now... this can somehow be done with less flexibility using a videoskin
EDIT : I'm wrong, this always works and more easy by the way ^^
Just set text effect to your needs and activate then :
get_loaded_song 'comment' & param_cast text & effect_string 'text' 2
i.e. with onload
i.e. with onload
geposted Wed 17 Mar 21 @ 11:40 am
Text effect still has 2nd string parameter as text, it's the 3th string parameter that is preset (and 1st is font)
geposted Wed 17 Mar 21 @ 11:48 am
Sorry Adion did not saw your message, no notification while editing :\
geposted Wed 17 Mar 21 @ 12:03 pm
@NICOTUX and Adion
how do I have to do that, it doesn't work that way
geposted Wed 17 Mar 21 @ 12:09 pm
Source of the confusion:
string 2 name is Preset
string 3 have no name and contains preset
https://imgur.com/a/T5AH8BO
@Benz Werner
It's a little specific:
If you enable text as master video effect you need to specify decks
i.e.:
"deck active get_loaded_song 'title' & param_cast text & deck master effect_string 'text' 2"
@Benz Werner
i.e.:
geposted Wed 17 Mar 21 @ 12:17 pm
@Benz Werner
i.e.:
@Benz Werner
i.e.:
Hi NICOTUX,
Unfortunately it does not work
Do you understand German?
geposted Wed 17 Mar 21 @ 12:59 pm
Hi ADION,
please do the Video FX plug-in described above
because the text plug-in does not work
geposted Wed 17 Mar 21 @ 3:19 pm
Hi Dev Team,
I would like to request for video editor & track cleaner to be able to see POI cue points & markers.
This feature will greatly help us to do speedy editing and saving files.
vDJ Alfr9d
vDJ Alfr9d
geposted Sun 28 Mar 21 @ 12:09 pm
Hello,
any chance to get a "Browsersource" Plugin in Virtual DJ?
Like in OBS where you can use Streamelements and stuff to get stuff from the chat into the Video?
At the moment i use OBS with Browsersource + Virtual Cam to get that into the Virtual DJ Video Broadcast.
Would be so nice get this straight into VDJ like the Text Plugin or stuff...
geposted Tue 27 Apr 21 @ 9:46 pm
Would love the Logo transition mix emergency has where a DJ uploads his logo and the video transition is his log! Can virtual do that as well?
geposted Tue 04 May 21 @ 8:19 pm
1. I would like the ability to record the video feed from VDJ
2. Also, I wish the "pop out" control panels for video were adjustable in the size of the control toggles. When one is busy mixing music and controlling the video, precisely clicking the very small controls is tedious and time consuming.
3. Another good thing would be able to screen capture for either of the video inputs and be able to mix between the two.
geposted Fri 14 May 21 @ 9:20 pm
