Topic: Urgent issue RAM
vjmundyPRO InfinityMember since 2014
When I activated video preview and THEN I CLOSE IT, the process TCCD run making this disaster. This process only grow up when VDJ8 is activated. Use a huge amount of Ram memory and increase without limits.
geposted Tue 27 May 14 @ 9:13 pm
What version build VJD8 are you on? I had the same issue with a previous build and reported it. I don't have this issue since updating to 8.0.0 build 1814.669.
As a side note I also repaired permissions using Apple Disk Utility which fixed my keychain, also associated with the tccd process. I'm not an expert but these are the two things I found so far.
geposted Wed 28 May 14 @ 3:06 pm
geposted Wed 28 May 14 @ 11:53 pm
somebody of staff have seen the video?, i feel ignored.
geposted Thu 29 May 14 @ 10:01 pm
HomeboyPRO InfinitySupport ManagerMember since 2003
This has been reported. We will look into it. Thanks for posting the video as well.
geposted Fri 30 May 14 @ 11:11 pm
