Topic: Kam digi two
Upgraded to v8 pro but tracks won't load useing upload buttons
geposted Sat 31 May 14 @ 3:58 pm
What is the exact name that the device gets in Config-->Controllers tab ? It should be something like Generic/ ME etc.. can u check please ?
geposted Sat 31 May 14 @ 6:55 pm
Hi djdad.
Sorry for posting twice not good at this will try harder.
It comes up as Generic me-800
geposted Thu 05 Jun 14 @ 3:05 pm
The mapping needs to be simplified and changed. We will do that shortly.
But in the meantime you can simply map the LOAd buttons as .. load.
To do that...
- With your controller connected, open the CONFIG window of VirtualDJ and goto the CONTROLLERS tab.
- Select the Generic ME-800 device from the top left list.
- Push one of the LOAD buttons on yoru controller.
- The LOAD key will appear in the Keys list (bottom-left)
- Select the LOAD Key from the list.
- Delete the entire long action you will see in the action field, and then simply type .. load in there
- Close the Config and give it a try
geposted Thu 05 Jun 14 @ 3:19 pm
Hi djdad.
Thank you very much now working.
bobthedj1
geposted Thu 05 Jun 14 @ 4:01 pm
Hey there apologies for reopening the thread but i am having the same issue with the kam DiGi two tryed the mapping technique you previously posted but still no luck
geposted Tue 30 May 17 @ 9:00 pm
