Topic: Kam digi two
Upgraded to v8 pro but tracks won't load useing upload buttons
geposted Sat 31 May 14 @ 3:58 pm
What is the exact name that the device gets in Config-->Controllers tab ? It should be something like Generic/ ME etc.. can u check please ?
Hi djdad.
Sorry for posting twice not good at this will try harder.
It comes up as Generic me-800
The mapping needs to be simplified and changed. We will do that shortly.
But in the meantime you can simply map the LOAd buttons as .. load.
To do that...
- With your controller connected, open the CONFIG window of VirtualDJ and goto the CONTROLLERS tab.
- Select the Generic ME-800 device from the top left list.
- Push one of the LOAD buttons on yoru controller.
- The LOAD key will appear in the Keys list (bottom-left)
- Select the LOAD Key from the list.
- Delete the entire long action you will see in the action field, and then simply type .. load in there
- Close the Config and give it a try
Hi djdad.
Thank you very much now working.
bobthedj1
Hey there apologies for reopening the thread but i am having the same issue with the kam DiGi two tryed the mapping technique you previously posted but still no luck
