still dealing with the echo shuting off if i start another record on the same deck.
thas very extrange, im using the scipt on crossfader(advance)and working perfect,my console hercules rmx.
geposted Mon 01 Dec 14 @ 7:15 pm
Djratedxxx919 wrote :
It works but im still dealing with the echo shuting off if i start another record on the same deck....so im still not getting true PFFX but it does sound good. Loco you are a genius still.
geposted Mon 01 Dec 14 @ 7:16 pm
too kind, have you set FX reset to no?
http://pbrd.co/1v7Wdwc
geposted Mon 01 Dec 14 @ 7:38 pm
Ok if i activate the effect move crossfader to right, the effect engages, but when i load the next track and go to mix it in bring crossfader to middle it kills the echo trails...if i turn off the effect it kills the trails...the echoes should continue no matter if the effect is cut or another song is mixed in....
geposted Mon 01 Dec 14 @ 9:29 pm
Use the traditional Xfader mapping and see if that's better.
geposted Mon 01 Dec 14 @ 9:39 pm
Okay that was better but i think being this is a mapping the way locodog mapped mapped my m70 to mimic PFFX using decks 3&4 if a better fit for me because the echoes fade out without stopping the effect. I do 2-5 sec transitions sometimes so I need it to continue uninterrupted..even if i turn the effect off. So come on VDJ make us a real PFFX.
geposted Mon 01 Dec 14 @ 10:07 pm
That I can do but the traditional xfader is absolutely as real as post fader gets, bleed and everything, even traktor bleeds track to track
When Atomix do it, it'll be like that.
What you're describing is a fading sample loop (possible)
(on the vci380 you only run 2 decks off it?)
geposted Tue 02 Dec 14 @ 3:30 am
@ min 1.55 I turn On the locodog's post fader FX
geposted Fri 05 Dec 14 @ 10:44 am
