Topic: Virtual DJ 8 Font Size
Love the new software,great job.Would it be possible in a future build to increase the font size in the search bar and if possible darker font in the configuration section,maybe a bold font option in general,thank you.
geposted Sun 29 Jun 14 @ 12:59 pm
Increasing the font size in the search bar, has been asked for, and acknowledged. Just looked at the options text, and I see it OK, and I wear glasses.
I just added this option to my BlackSheep skin.
Thank you for the reply,just that my eyes are really bad or else I won't have even posted this,the skin I use in Virtual Dj 7 I changed the font size and type myself in the XML file.
How do I increase the font size and the search key on VDJ 8?
press A here:
I don't see text under option. Only trying to make my font size larger. Please help. Thanks.
It helps me too :) thanks
THX
Thank you it was so easy
