SBDJ wrote :
Use fsvalue2, fscommand2, fsvalue3 and fscommand3.
I'm sorry but I think I've tried every combination using "," "&" not using "set" or "$"
sometimes only first command works and sometimes only the second.
Can you please write an example of the whole string using commands 268 and 279
Thanks.
geposted Thu 11 Aug 16 @ 5:33 am
set $fsvalue 255 & set $fscommand 268 & set $fsvalue2 255 & set $fscommand2 279
This requires the latest version of the plugin (22nd Dec 2015).
geposted Thu 11 Aug 16 @ 1:50 pm
OH, now I see what I was doing wrong. It's working perfectly now.
Thank you so much for your help and also for this awesome plug in, it's the only reason I switched from serato to vdj.
geposted Fri 12 Aug 16 @ 5:28 am
There's a new version in the works with some new features too :)
geposted Fri 12 Aug 16 @ 9:19 am
You do understand from now people will ask for the next release every day because they're missing out now? ;) LOL
Very curious what the new features will be.. The current plugin is very good if you ask me.
geposted Fri 12 Aug 16 @ 10:24 am
New features at present:
Beat multiplier - 1/8, 1/4, 1/2, 1, 2, 4, 8
Status information retrieved from Freestyler to use in queries, skins and controller LEDs
Macro support
Macro support
geposted Fri 12 Aug 16 @ 9:15 pm
Hi, is there a possibility to use the VDJ customs pads with FS-commands? Or does freestyler8 with commands only work in the POI's?
grtz
grtz
geposted Mon 22 Aug 16 @ 7:57 am
freestyler works with script, so pads, custom buttons, poi they're all ways of delivering script.
geposted Mon 22 Aug 16 @ 8:10 am
OK thanx
i do not now where to add it in the 'pads editor'
I could create a 'new pads page'...
But next...what category do i choose? (param, variables,...)
grtz
My problem is...do not know which category use, to write the commands down.
Can you help me out? grtz
grtz
geposted Mon 22 Aug 16 @ 9:48 am
just write the commands, categories are only there as a memory aide.
geposted Mon 22 Aug 16 @ 2:43 pm
Works great !!! godsend present....thank you very much.
grtz
i do seem have an issue with freestyler8, mentioned it before her, got deeper in it today.
when enabling 'beats half speed', it does works fine but got stuck in it, cannot disable it.
tried to solve this with 'release all cues' in freestyler, no good.
restarting freestyler also didn"t solve it.
neither enabling, disabling, change settings in freestyler8.
unplugging the fixture also didn't solve the problem either.
http://www.manualslib.com/manual/925001/Ayra-Intenz-Cb-150.html#manual
the only way to solve this was restarting VDJ.
and not using 'beats half speed....;-)
grtz
geposted Mon 22 Aug 16 @ 6:23 pm
Beats half speed is function of the plugin, not freestyler itself.
geposted Mon 22 Aug 16 @ 6:31 pm
Hi guys, the Script Generator is empty on mine. Anyone know how to get it working?
BTW amazing work... it have it currently working on Sound mode and can use black out cues. But id love see use the generator as it looks like it makes everything so much easier.
Again thanks guys
Again thanks guys
geposted Sat 10 Sep 16 @ 1:06 pm
It's a bug - it's not actually empty, just the dropdown is really small. You can scroll it with a mouse or cursor keys though.
geposted Sat 10 Sep 16 @ 3:50 pm
Any idea when the new version of the freestyler plugin is going to be released into the wild ? The beat divider/multiplier changes is something i am particularly looking forward too. Awesome plugin :-)
geposted Thu 22 Sep 16 @ 7:30 am
Good day. On the plugin download page it specifically states that this plugin works with PRO and PLUS. Imagine my disappointment when I purchased a PLUS license and this doesn't appear under the Master drop-down.. Not great from VDJ's side..
Scrolling through the messages, I see that you say there is a technical reason why this doesn't work with PLUS - is there a work-around or is a PLUS version a work in progress? This might save me carrying another laptop to control FreeStyler.
Thank you.
Thank you.
geposted Sun 30 Oct 16 @ 11:06 am
The Addon is probably auto-installed in the Plugins/AutoStart folder. I suppose you can copy the dll and paste it in the Plugins/SoundEffects one.
geposted Mon 31 Oct 16 @ 6:33 pm
That seemed to work. Thank you.
geposted Fri 04 Nov 16 @ 8:56 pm
so for mac users you have to be bootcamped to use this correct?
geposted Sun 20 Nov 16 @ 2:29 pm
there's a MAC download so i would say no.
geposted Sun 20 Nov 16 @ 3:22 pm
