Forum: Addons
Topic: MULTI TouchScreen - Page: 6
HI dj DaD could it be possible to add a Mirrored Wave to the wave section to this already Kool Skin??? it should be Appreciated...Great Work Loving it, Thanks.!!!
Interesting variation skin... I have a 24 inch external Dell touch screen that I have not tried this on. It is perfect for my 16 inch screen. I am used to the VDJ default skin where dragging the song to the player doesn't require switching back and forth. However, the larger effects buttons and replacement around the platters is really nice. I'll have to give this a test run and see how I do.
Nice job!
Can you please tell me the function of the two buttons circled? Thank you!
Figured it out, thank you.
Hi Guys, Can someone help me with this skin which shows up only two decks, even though i am using a 4 deck Numark NS6ii . i dont see the pads at all when i load this skin... Am i missing something here ? btw i am using a mac version.
Never mind... found it :) thanks
hello, I do not find in the browser view any deck-load button, is there any one?
Thank you for this great skin! I've used it on my touchscreen ThinkPad without a controller, and an external USB soundcard and it works just fine. Takes a short while to familiarize with the various controls... But once you get it.. you're good to go..
Hello! I wonder if you will upgrade the skin to the 2020 version? Thank you!
Hello everyone and thank you dj dad for the creation of this skin MULTI TOUCH.
Among you someone or dj dad would it be possible to know how to be able to use the CUES points from 9 to 16.
OK the CUES points from 1 to 8 are really good but I would really like to use more cues with this skin.
I hope you can help me.
DjPapaDjee
I put this 'effect_select' in a custom button. It opens a menu to the effects. Clicking the gear wheel will open a floating panel with knobs.
Moderator; you're replying to a two year old post.
Hello, I really need your help.
I use because I love the Multi touch skin.
Especially for the big colored buttons of the CUES points.
But the problem that I cannot solve is:
1 If I press the cue point buttons I have the arrows on the right to go from 8 cues to 16 cues.
But if I call the samples page and I come back to the cues button page I can no longer change the cues pages and go from 8 to 16 cues. But only the cues 1 by 1 and I cannot correct without leaving the skin and choosing an old skin.
Hi djdad
Is there a way to change the scroll width for song lists in your Multi Touch Skin?
Thanks in advance!
if talking about the right side scrollbars the answer is no it's fixed in browser
if about the size of the list ... as usual, moving the split sepatrator
the touch skin is using "multiTouchTwoFingersScroll" so that the whole lists can be used to scroll the lists
The mic duck button under inputs does not stay ON and it deactivates the Mic ON button when touched. I have to hold it down to get the ducking feature and it seems when I hold it down, it drops the decks volume to achieve this....
Is there a way to have the MIC DUCK stay on? Or is that the way it is (supposed) to work?
I'm using this skin on a Thinkpad yoga (L380) convertible. I have a USB soundcard connected and split headphone and mic into a Logitech gaming headset, and master out via the laptop headphone jack to external speakers...
Thanks for any help.
Thank you djdad for the great work. I'm not a dj but a musician and I use your great skin for backing tracks to my gigs. It has everything except....the key for the song(Am, D, Cm etc.). This would be maybe one of the most useful things for a musician or a singer. I know you hate requests as you said to your profile, but PLEASE, this is very easy for you to do it, or guide me to do it.
Thanx anyway
Euripides Stamos
Waiting for an official update you can try to edit the skin by yourself
https://imgur.com/a/WMZK1FK
(mis-aligned right key in picture - with cyan anotation - are fixed here)
setting -> interface, select the skin & click "Edit this skin" top right link
tiny hack to apply to the xml file:
(Specified lines # take in consideration the inserted lines count)
TO ADD key on top of pitch buttons, align with pitch in controller mode
lines 1624 & 2476 (left deck 1, 3) add the following textzone
<textzone>
<pos x="-5+82+14" y="-15" width="82" height="16"/>
<text size="24" align="left" weight="bold" action="get_key 'musical'" color="`get_key_color`"/>
</textzone>
lines 3369 & 4219 (right deck 2, 4) add the following textzone
<textzone>
<pos x="+5" y="-15" width="82" height="16"/>
</textzone>
Next to ADD Key side of bpm (in browser mode)
5889 & 5919 (left deck 1, 3) replace existing textzone with
<textzone class="textcolorline1" group="horizontal">
<pos x="900-60-80-4+14+55" y="117" width="120" height="22"/>
<text align="left" weight="bold" size="20" format="%Pbpm "/>
<text size="20" align="left" weight="bold" action="get_key 'musical'" color="`get_key_color`"/>
</textzone>
5944 & 5973 (right deck 2, 4) replace existing textzone with
<textzone group="horizontal">
<pos x="900+60+52+8" y="117" width="60+60" height="22"/>
<text color="#AAAAAA" align="right" weight="bold" size="16" format=" BPM : "/>
</textzone>
then save and do not forget to select (edited) version of the skin
Hello Dj Dad, your valuable help please,
i need a code or script to jump between deck 1 and deck 2 only, together with PFL, without deck 3 and 4 tour, when using two decks only.
Like a selector button that allow to use two decks or Four when is necessary.
Thanks in advanced.
Hello friends,
1question, is possible to show de Cover fan mode in the sidelist view in browser panel..? please confirm or indicates to enable it and view.
may be require some XML modification.
Hello DJDad, another question or help request, some code to show the browser in Fan mode view, im not sure it is possible, help please.
U can see image attached: https://imagizer.imageshack.com/img923/5481/7J7ob1.jpg
img [https://imagizer.imageshack.com/img923/5481/7J7ob1.jpg] /img
img[https://imagizer.imageshack.com/img923/5481/7J7ob1.jpg]/img
67%
