Forum: Addons
Topic: MULTI TouchScreen - Page: 7
Hello Nicotux, do u know some code to show the browser in Fan mode view, im not sure it is possible, help please.
see image attached: https://imagizer.imageshack.com/img923/5481/7J7ob1.jpg
img [https://imagizer.imageshack.com/img923/5481/7J7ob1.jpg] /img
img[https://imagizer.imageshack.com/img923/5481/7J7ob1.jpg]/img
QND working version: (full size coverflow)
line 5991: replace "<split name="folders" type="horizontal" ..." with
<split name="folders" type="vertical" position="20%" >
<size width="1870" height="780+60-30" />
<pos x="23" y="222"/>
<up>
<coverflow x="0" y="0" width="1870" height="780+60-30" resizeX="no" resizeY="yes" attachX="both" attachY="both" />
</up>
<down>
<split name="justfolders" type="horizontal" position="20%" resizeX="no" resizeY="yes" attachX="both" attachY="bottom">
and add
6295:
</down>
<separator close="up" closed="no" size="0" />
</split>
just before
</panel>
Ok, my apologies Nicotux, i meant similar to Essential skin, showing others panels too, folders, songs list and sideview, thank u Nicotux.....
In other request, i appreciate your valuable help please with a code or script to jump between deck 1 and deck 2 only, together PFL, without deck 3 and 4 tour.
Like a selector button that allow to use two decks only, or Four when is necessary.
Thanks in advanced.
why not, will redesign the whole skin :)
line3 add
<nbdecks value="2" condition="var_equal '@$4decks' 0"/>
<nbdecks value="4" condition="var_not_equal '@$4decks' 0"/>
line 1043 modify action ( allow to toggle mode by long press)
<button class="buttonsmall" action="holding ? toggle '@$4decks' &amp; load_skin : get_decks &amp; param_bigger 2 ? var '@$4decks'? deck 3 leftdeck" tooltip="Long press toggles 4 decks mode" >
line 1307 modify action ( allow to toggle mode by long press)
<button class="buttonsmall" action="holding ? toggle '@$4decks' &amp; load_skin : get_decks &amp; param_bigger 3 ? var '@$4decks' ? deck 4 rightdeck" tooltip="Long press toggles 4 decks mode">
Oh Wao.... excellent Nicotux, could be possible to link button with PFL for each one deck when using two deck only, or to activate PFL at same time when selet a deck?.
How can adjust code for this request..
You are the specialist.
just add 'select' to toggle actions
i.e.:
"holding ? toggle '@$4decks' &amp; load_skin : select &amp; get_decks &amp; param_bigger 2 ? var '@$4decks'? deck 3 leftdeck &amp; select"
"holding ? toggle '@$4decks' &amp; load_skin : select &amp; get_decks &amp; param_bigger 3 ? var '@$4decks' ? deck 4 rightdeck &amp; select"
note: there is a bug to fix when going back to 2 decks when 3 and/or 4 are selected
Hello Nicotux, please tell me what about the deck selector bug when going back.
One more question, it is possible to enlarge the scratch hand pointer or mouse cursor mask, when mouse is over the Jogwheel. it is the mousemask i think.
May be change color too, please confirm.
Than you :)
simply when one of the deck 3 or 4 is selected going back to 2 decks mode can't display decks 1 & 2 only, selected decks still appear as selected
yes Jogwheel is a mousemask
1680 <mousemask x="684+400" y="2332"/>
1735 <mousemask x="684+400" y="2332"/>
2532 <mousemask x="684+400" y="2332"/>
2587 <mousemask x="684+400" y="2332"/>
3427 <mousemask x="684+400" y="2332"/>
3482 <mousemask x="684+400" y="2332"/>
4277 <mousemask x="684+400" y="2332"/>
4332 <mousemask x="684+400" y="2332"/>
replace all with :
<mousecircle x="-10" y="-10" r="180"/>
Thank U very much Nicotux, please excuse my english,
i meant to say enlarge size of the graphic hand in black color and change the color if possible, when is scratching over the disc plate.
Something like this: https://imagizer.imageshack.com/img922/860/YhqfHV.png
The "hand" icon is built into the VDJ code. It's not part of the skin graphics.
You can enlarge the mouse pointer via your operating system, but the enlarged hand does not look good (low resolution).
Understood, thank you a lot guys, ready. This is a great forum.
Hello Nicotux, Bless,
Please help me with a code to make a CUE pad Blink only once each time i press the button, to make reallistic effect of pressing a button.
Similar when press the CUE_Stop button when song is loaded or make more incandescent flash when press the button.
In case to set color to another button, normally color light DIM when off, and color light is full ON when activated, i would like when i press this button its make one blink briefly, may be a short off momentary while pressed.
normally when Cue is not set, color light DIM, when the Cue is set color light is ON.
Don't really know maybe need a custom hotcue pad page for that or a big skin mod to apply only on cues
anyway this can be somehow acheive for any pad
prepend visibility of visual with things like that (change pad number and level accordingly)
pad_pushed 1 & pulse 200ms ? get_constant 50% :
i.e.: line 2303 (left pad 1)
<visual source="pad_button_color 1" visibility="pad_color 1 ? true : false">
becomes
<visual source="pad_button_color 1" visibility="pad_pushed 1 & pulse 200ms ? constant 50% : pad_color 1 ? true : false">
hello to all would it be possible in this skin to be able to add POIs to samples? If so how or script please. Thanks for your help.
Samples can have POIs nothing to do with a skin or script:
drag/drop your sample to a deck, open POIs editor, edit and save, unload
but sampler does not take them in consideration so that they are useless
Thank you a lot Nicotux, code is perfect and functional. You are the key :)
I think it's a nice feature i never thought about before
but as usual, there are issues
padshift_pressed does not exist ^^ and pad_pushed can't apply
padshift_color either ^^
we can set padshift colors in pad editor them but they are useless
78%
