- fix timecode drift in relative mode
- can adjust timecode pitch parameters in options
- fix playing files longer than 26 hours
- Fix automix noise with pitchQuality 2
- Fix ramp up/ramp down in combination with motorized jogWheel
- crossfader_disable action added
- autoMixBeatmatchOnFade made optional
- autoMix time remaining more accurate
geposted Wed 10 Sep 14 @ 4:07 pm
new build crashes, mac osx 10.7,here is the report
geposted Wed 10 Sep 14 @ 5:24 pm
same here. Update issue on Mac.
geposted Wed 10 Sep 14 @ 6:24 pm
FYI... I don't get beta updates but I see some people on the facebook page saying their Macs are crashing with this update also.
geposted Wed 10 Sep 14 @ 7:09 pm
One thing I noticed, (relevant? IDK) I updated (windows) by downloading a zip and not via VDJ and this zip the exe was VirtualDJ and not the usual VirtualDJ8.
I don't know if that matters (Probably not), just something I spotted.
geposted Wed 10 Sep 14 @ 7:36 pm
We are waiting for instructions please.
geposted Wed 10 Sep 14 @ 8:12 pm
should be fixed now.
geposted Wed 10 Sep 14 @ 9:32 pm
Timecode Working perfect ,i move the new settings and its great...... Good job im on windows 7 ,I havent try on Mac ,ILL try tomorrow....
geposted Thu 11 Sep 14 @ 2:13 am
new build 1957.804 : still static noise when scratching slow.
looking forward
thank you
looking forward
thank you
geposted Thu 11 Sep 14 @ 2:30 am
@vdj_pARtybOy,
Try to set "PitchQuality" to 1 in advanced options (if it is 2).
Is it better ? it should.
geposted Thu 11 Sep 14 @ 3:10 am
1957 804
motorized dishes seem ok with Mac & NS7II
also the starting point at the start is good
slow start is ok now
I run other tests
I run other tests
geposted Thu 11 Sep 14 @ 3:12 am
Regression bug: This update is killing my CPU using time codes, my i7 is struggling to do tasks it used to handle like butter and i'm hitting red constantly. Please optimize the code
Latency at 10ms
sample rate 44100
Latency at 10ms
sample rate 44100
geposted Thu 11 Sep 14 @ 4:48 am
Latency at 10ms
sample rate 44100
Latency at 10ms
sample rate 44100
Still testing to see what could be a reason for my increase in CPU, i'll revert to build 1932 to see if the issue remains the same but so far no issues with drift, smart mode isn't that accurate and will sometimes lose cue positions on CDJs but I suppose that's not a big issue, just need to narrow down what's causing the demand for more CPU on my PC. Thanks
geposted Thu 11 Sep 14 @ 5:58 am
Random Pitch jumping still happening.
geposted Thu 11 Sep 14 @ 7:54 am
ok everything is good so far but the most importing thing is not fix the pitch delay on timecode vinyl i try timecodepitch sensitivity thru 0 to 100 and there is still a delay and timecodepitch speed same thing o to 100 and there is still a delay when u move the pitch silder on the turntable the software does not keep up.please we need this adjusted we can not mix or blend.help help help.very importing thank u
geposted Thu 11 Sep 14 @ 7:56 am
How does a build that doesn't run on a Mac get released? :-(
I thought the quality was getting better...
geposted Thu 11 Sep 14 @ 8:11 am
Not sure how they can be so confident with users being very happy with the updates and yet still experience issues. Boggles my mind!
geposted Thu 11 Sep 14 @ 8:12 am
apopsis wrote :
@vdj_pARtybOy,
thanks for the feedback,but no, not better,sounds the same in 1 or 2 pitchquality, also tried scratchfilterquality 8/16/32...
looking forward
geposted Thu 11 Sep 14 @ 8:55 am
Not a regression but a suggestion to DEVS. Is it possible to have an option to disable the pitch slider? the visual delay creates a placebo effect I feel
geposted Thu 11 Sep 14 @ 9:59 am
It's already possible, just jack one of the pitch settings number super high and it doesn't move..........and really a placebo effect, come on already.
geposted Thu 11 Sep 14 @ 11:37 am
