Topic: VDJ8 SCRIPT
Can someone tell me how to map the parameter left and right buttons on the DDJ- SX to pitch bend.
I know in vdj7 it was Hot_CUE PARAM+ was the button name and action learned was pitch_bend +5% 500ms
geposted Sat 27 Sep 14 @ 1:39 pm
Each mode (CUES, LOOP, SLICER etc) has a different key for the Parameters Buttons. So you will need to use the same (above) action for all the Keys.
geposted Sat 27 Sep 14 @ 6:20 pm
Is there a way to determine if a video is playing via script? I know you can determine something is playing but includes both audio and video and no distinction.
geposted Sun 28 Sep 14 @ 6:17 am
video action will return if the video is activated.
deck x is_video .. will return true if a deck is loaded with a video file
deck x is_video ? deck x play ? ... will return true if a deck is playing a video file
If you query all decks, you will probably get what you want.
geposted Mon 29 Sep 14 @ 1:55 am
I'm use to the pitch bend buttons on my NS6 so I want to map the parameter buttons to respond the same as the pitch bend on my other controllers I don't use the pads other than Launching samples and drops.
geposted Mon 29 Sep 14 @ 10:10 am
I upgraded to the DDJ-SX from the NS6 and from VDJ7 to the VDJ8. Here is my issues, the NS6 sounds fine with VDJ7 I can back spin and scratch and scratch drops with no problems. When I try the same with the DDJ-SX the platters sound like digital rewind on the back spinning and back cueing, the song lags and throws off the timing of the drop and it don't sound like a natural scratch. So I started to use the VDJ-8 with the DDJ-SX and The sound is better but it lags slightly when loading songs the screen freezes but the sound continues. After a while of playing VDJ-8 it closes and restarts. I would also like to know if there is a way for VDJ-8 to read the hot cues set in VDJ-7 this was a problem for me when I went live with VDJ-8 and DDJ-SX for the first time. The browser did not recognize a playlist I created hours prior to going live this past weekend, but recognized did the older playlist I saved. I reset the software twice prior to starting and didn't see the new play list. I went into windows VIRTUAL DJ folder and found the playlist in the playlist folder but could not use it that night.
Thanks!
geposted Mon 29 Sep 14 @ 10:35 am
What is your pitchquality setting in advanced options? Problems occur with setting 0
geposted Mon 29 Sep 14 @ 8:43 pm
If you've created the playlists with VDJ 7 read this:
PhantomDeejay wrote :
VirtualDj 8 will read VirtualDj 7 database only ONCE (the first time you launch it) and it will create it's own.
After that point any changes you make in version 7 are NOT reflected in version 8 and vice versa.
geposted Tue 30 Sep 14 @ 2:37 am
Have you solved the crashing issue?
geposted Tue 30 Sep 14 @ 9:04 am
