when i try to remove tracks from DB, the XML file still contains stil all the fileinfos.
When i remove tracks vom DB, update the tag files external and put them in VDJ Database, the old tags will be shown.
workaround:
You must "reload tags" to correct this
correct way:
remove all the informations from database xml when tracks are eletet from DB
workaround:
correct way:
geposted Sun 19 Oct 14 @ 11:10 am
'Reload tags' is the correct way to update the database if external changes to the database have been made.
Remove from DB flags the file so that it will not be shown in search results for example. If it would remove the entry from the db, then the next time you browse that folder it would simply find it as a new file and add it again.
geposted Mon 20 Oct 14 @ 3:18 am
ok. you should now have a closer look to this bug:
http://www.virtualdj.com/forums/194877/VirtualDJ_8_bug-report_Forum/MP3_Tag_field_grouping_wont_updated_with__reload_tag_.html
Without deleting the file in db, there is no way to update the grouping (contentgroup) tag field.
geposted Mon 20 Oct 14 @ 4:32 am
