Forum: VirtualDJ Plugins
Topic: VirtualDJ8 & PocketCam - Black screen when Pocketcam selected
glennHome userMember since 2014
I'm trying to use Pocektcam as a wireless camera for VirtualDJ8. When i select Pocketcam in the camera plugin i get a black screen, when i select the built-in Facetime camera it works fine. I can see the video int he pocketcam preview window just fine. I even purchased the full version of Pocketcam just to make sure it wasn't related to the light version.
I also noticed that the Photbooth App doesn't work with Pocketcam either however the Facetime app does. I can select the PocketCam drive in the photobooth app but it just hangs and shows all black too.
Has anyone been able to get Pocketcam working in VirtualDJ 8 ?
geposted Mon 20 Oct 14 @ 10:59 pm
If you are using a PC you can try iPhone / Pocketcam using TellyMedia on VDJ8. TellyMedia gives you more camera options and will work for a greater variety of cameras. Also gives you more in terms of Video, Images, Slideshows, audio, etc.
I would like to know whatever you decide. You can download TellyMedia for VDJ 7 or 8 here:
http://www.tellyvisuals.com
geposted Tue 21 Oct 14 @ 4:53 pm
Meant to say I would like to know if it works or not regardless of what you decide to do now or later.
geposted Wed 22 Oct 14 @ 4:18 am
