When trying to edit info using tag editor, it automatically crashes vdj.
geposted Wed 29 Oct 14 @ 2:09 am
No colored waveforms (songpos) here.
11:15pm
Tried it on another pc and everything works, so it's something else (my problem)....
11:15pm
geposted Wed 29 Oct 14 @ 4:22 am
Windows or Mac? I have tried this a few times on the Mac release and it appears to be fine for me.
geposted Wed 29 Oct 14 @ 7:55 am
I see no mention of slipmode and changing loop lengths being fixed, but it appears it is,
Original report
http://www.virtualdj.com/forums/190289/VirtualDJ_8_bug-report_Forum/Slip_mode___changing_loop_lengths.html?search=slip%20mode&page=1
Confused (did it get fixed by accident?) but happy.
Original report
geposted Wed 29 Oct 14 @ 9:06 am
Mac, never had a crash until this build.
geposted Wed 29 Oct 14 @ 12:39 pm
I suppose the crash occurred with the NS7II, correct ? Have you modified any of its assigned actions or using he default one ?
geposted Wed 29 Oct 14 @ 3:02 pm
2021 Seems to be stable on my machine now. During stress testing my cpu stayed comfortably under 30%. It seems that 2021 causes a slightly higher CPU idle point.
geposted Wed 29 Oct 14 @ 10:06 pm
Yes the NS7II was connected. The only thing I did was add a script to the ONINIT to use channel 4 as the sampler output, but i did this in build 2003. Never had any problems till 2021. Also I got that widgets debug alert popup whenever i click on settings.
geposted Thu 30 Oct 14 @ 1:11 am
On my Mac, the CPU usage is now quite nil compared to the yesteryear of V8. (1923 was the first version that started to get this correct, and it's been better and better with each subsequent version.) - CPU pre 1923 was 60%+.
geposted Thu 30 Oct 14 @ 10:26 am
Please try to delete the application file and the settings.xml file, and then re-download and re-install the Mac beta build.
geposted Thu 30 Oct 14 @ 10:31 am
Hello there, I had a scriptting,created and shared by locodog, to have post fader FX, since the new build 2021 came out, the script stopped working! I miss it already....
is Atomix working on PFX option? will it be implement in next builds??
looking forward
thank you
looking forward
thank you
geposted Fri 31 Oct 14 @ 5:50 am
