Yes! For strip club dj's where actual mixing of tracks is not particularly required, it makes life/work a lot easier.
geposted Sun 01 Mar 15 @ 5:30 pm
Why is it that VDJ7 is actually more intelligent at Automixing than VDJ8?
I DJ multiple weddings every weekend and need the automix to work properly for Prelude, Cocktail, and DInner music. The Automix worked EXCELLENT in VDJ7, but VDJ8 totally sucks - it's not even close to 7's intelligent auto-sensing skills for the intro/outro fades. For instance, in VDJ7, I can set Automix on "Fade Intro/Outro" mode with 4-second cross-fading - all the tracks blend together beautifully, no silence or long fades between any tracks can be heard. However, in VDJ8, I have to set the crossfade time to 8 seconds (double the length) in order to avoid silences and drawn-out fades in between tracks. This is all while on the "remove Intro/outro" intelligent mode and it simply doesn't intelligently remove silences and low-volume points in the beginning and end of each track like the superior auto-sensing in VDJ7. Should VDJ8 be better at this at not worse? At least make it the same, please!
geposted Fri 06 Mar 15 @ 5:28 am
Yes
geposted Mon 23 Jan 17 @ 11:22 am
Yes ,i use this often on my Mobile DJ Jobs,in Pubs ,Bars,on Partys etc.
when Real mixing is not wished by Host and Guest.
greatings,Dirk
greatings,Dirk
geposted Mon 23 Jan 17 @ 1:06 pm
If you still feel the need to discuss this, please do so in the version 7 forum, thank you.
Locked by AMAHM
Locked by AMAHM
geposted Mon 23 Jan 17 @ 8:02 pm
