Topic: shift_all_cues adjust beatgrid too
shift_all_cues does not only moves the Cues. It will move the Beatgrid too.
shift_all_cues -40ms should only move the cuepoint. The grid could be moved with adjust_cbg.
Workaround till fix:
shift_all_cues -40ms & adjust_cbg +0,086
(40ms is needed to fix Serato Cue Import)
geposted Sat 06 Dec 14 @ 2:15 pm
ProfLeePRO InfinityMember since 2011
Thanks for sharing this.
geposted Tue 09 Dec 14 @ 7:00 pm
