Option 'keepSortOrder' is not working.
neither YES nor NO will affect the visibility of the sorting columns
geposted Fri 19 Dec 14 @ 4:52 am
What do you mean by visibility?
When it is on, and you sort a folder by Artist for example, browsing through different folders they will all be sorted by Artist on opening.
When it is off, and you sort a folder, after you move to another folder it is sorted again in the default sort order.
geposted Fri 19 Dec 14 @ 5:26 am
sorry, for my rusty englisch
all folders are in the same sorting order. With yes and with no....
geposted Fri 19 Dec 14 @ 8:26 am
