I've been using virtual dj 8 w/a Pioneer DDJ-SR since sept. with no problems. About 3 weeks after an update, my virtual dj started acting up. When I'm scratching or cueing a song up the track will "pause" about a half second after i release the platter. I'm on a new mid-2012 macbook pro, Pioneer DDJ-SR, and a Infinity licensed Virtual DJ8. Anyone have an idea for a solution? Thanx in advance.
geposted Wed 07 Jan 15 @ 12:42 am
What are your settings for touchWheelBackspin and touchWheelForwardspin
geposted Wed 07 Jan 15 @ 3:54 am
Is this the only issue observed with the SR ? Reason asking is because we have reports for all kind of weird issues (experienced one myself too), and it seems that there is a range of units with hardware/firmware faults.
Can you test with a different unit (if available) and see if the issue is controller related ?
geposted Wed 07 Jan 15 @ 3:00 pm
Touchwheelbackspin and Touchwheelforwardspin are both set to yes. That's the only major issue I'm having. Didn't have any problems until the day I did that update. Everything else is fine pretty much.
geposted Wed 07 Jan 15 @ 6:15 pm
I have a kontrol s4, but I never really set it up to use with VDJ. I usually only use it with Traktor
geposted Thu 08 Jan 15 @ 9:45 am
djdad
I have the ddj-sr and the ddj-sz. The ddj-sr has a issue when I open vdj 8 the jog/mode light is on but the vinyl mode is not working if I turn off
the jog/mode light then it works . I know that should be the other way around. Still playing around with it will let you know more soon.
geposted Thu 08 Jan 15 @ 9:11 pm
In v8 you need to be in serato mode for SR to work properly.
geposted Fri 09 Jan 15 @ 12:28 am
So The SR need sot be in Serato Mode?
geposted Fri 09 Jan 15 @ 8:36 pm
I have the same exact problem with my pioneer ddj-sx2 !! I need fixed asap if not ill have to use Serato but i like the VDJ options better PLEASE HELP !
geposted Mon 12 Jan 15 @ 9:10 am
These should be set to no otherwise there will be a short delay after releasing in each direction to determine whether the jogwheel is still moving or not (To allow the backspin/forwardspin to continue working.)
The normal default setting is Touchwheelbackspin yes and Touchwheelforwardspin no - This allows a manual backspin but no forward spin. Releasing on forward scratch movement will ensure there is no delay.
The only way to have no delay in both directions is to set both to no, but then you will not be able to perform manual backspins.
geposted Tue 13 Jan 15 @ 11:32 am
