setting 'showHorizontalSideList' does not work as an action
Will not work:
<item text="yes" action="setting 'showHorizontalSideList' 'yes'" check="setting 'showHorizontalSideList' 'yes'" />
<item text="no" action="setting 'showHorizontalSideList' 'no'" check="setting 'showHorizontalSideList' 'no'" />
reload / restart ....no way to get the changes into settings.xml
show a marker with check="setting 'showHorizontalSideList' 'yes'" dows not work too
Will not work:
geposted Sun 11 Jan 15 @ 4:31 pm
You need to reload the skin before the changes take effect, append your script with.
& load_skin
& load_skin
geposted Sun 11 Jan 15 @ 7:18 pm
i tested all.....
i tested all.....
geposted Mon 12 Jan 15 @ 3:42 pm
Now I understand, it's in relation to skinning, try this
setting 'showHorizontalSideList' off & load_skin
setting 'showHorizontalSideList' on & load_skin
geposted Mon 12 Jan 15 @ 6:48 pm
ahhhh.... in the settings.xml and in the options sections are written yes/no next to 'showHorizzontalSideList'.
When you use on/off for skinning, it seems to work fine. Somebody from Atomix staff should take some time and write down a complete SDK....This would be a great time saver.
THX locodog!
THX locodog!
geposted Tue 13 Jan 15 @ 2:56 am
