I have a bunch of video loops loaded into the sampler. they are avi, mov, wmv and mp4 files. Some of the files will cause VDJ to freeze then crash when I activate them. About 80% of my clips work fine but some just don't (they could be any file format). I have the video samples set to "loop", "Flat" and "Video".
I am on a PC using hdmi and the latest version of VDJ
Any help would be great.
geposted Tue 27 Jan 15 @ 8:06 am
can you specify what format the clips are that cause the issue ?
Please check also resolution and sample rate of the clips.
We need to gather more info and details about this ...
geposted Tue 27 Jan 15 @ 9:46 am
Best way is to post a video that causes a problem. Keeps guesswork down. Since this can be hard for some, it would probable be good if VDJ had a facility to upload media files for testing via the VDJ website.
geposted Tue 27 Jan 15 @ 9:51 am
I'm not at home right now but will do so this evening
geposted Tue 27 Jan 15 @ 9:53 am
I believed I solved the issue...I had a few corrupt video files.
geposted Sat 31 Jan 15 @ 1:12 pm
