in all the years that ive been using pc's to DJ i have never had a BSOD. today.. twice playing the same promo only video track that has played perfectly until now.
geposted Tue 10 Mar 15 @ 11:24 pm
more info: Laptop is a 17" HP envy. 4th gen i7, 8 gb ram with touchscreen. controller is a MC6000mk2, All drivers are up to date. using the latest vdj8 build. 2174. did it playing the same video which i play often.
geposted Wed 11 Mar 15 @ 1:33 am
I thought BSOD are caused by hardware issues...?
geposted Thu 12 Mar 15 @ 8:24 am
That's what I told em in his other post???? I think maybe I forgot.
Hardware failure or driver issue
geposted Thu 12 Mar 15 @ 11:59 am
what is the video causing this problem for you?
what are the specs of your machine??
geposted Thu 12 Mar 15 @ 10:13 pm
I have had the crash with different videos.. both promo only videos that were recently released. everything was fine until i downloaded the latest build. Before that these played flawlessly in both vdj 7 and 8
geposted Fri 13 Mar 15 @ 2:29 am
how to resolve bsods ->
windows7
http://windows.microsoft.com/en-us/windows7/resolving-stop-blue-screen-errors-in-windows-7
windows 8
http://windows.microsoft.com/en-us/windows-8/resolve-windows-blue-screen-errors
good luck
windows7
windows 8
good luck
geposted Fri 13 Mar 15 @ 5:12 am
DJ Maxx, you should cross check with a previous build where you were not having a problem. BSOD can be caused by hardware or software problems and I have seen both over the years.
geposted Fri 13 Mar 15 @ 9:54 am
yeah, this has only happened with the latest build... something in it it causing a conflict. With every previous build i had no such issue. Luckily this issue isn't present in VDJ 7
geposted Sat 14 Mar 15 @ 1:55 pm
So since these BSOD started happening, you've reverted back to an earlier build and they stopped? You've also run VDJ 7 since the BSOD and it works OK?
geposted Sat 14 Mar 15 @ 2:02 pm
This is the error message that comes up. Just happened again after I played a video.
geposted Sat 14 Mar 15 @ 9:05 pm
Here are the specs
geposted Sat 14 Mar 15 @ 9:08 pm
There is nothing attached I'm afraid.
geposted Sat 14 Mar 15 @ 9:47 pm
