Forum: Addons
Topic: GianB 4 Decks v3 - Page: 4
GianVJ wrote :
Changes "GianB 4 Decks v3.7.1":
- Fixed Jog Weel mode view on Jog
Thank you!
geposted Fri 16 Sep 16 @ 9:05 pm
GianVj
Thank you!
geposted Thu 13 Oct 16 @ 5:32 pm
Hi - Fun looking skin!
I'm having an issue (which I've had elsewhere in other situations...)
Using VCI-400, the PFL buttons on deck C and deck D both require TWO presses to turn on. ie. press, press, on. press, press, off.
The button lights up as it should with just one press.
Any thoughts on why this is happening?
Thanks
geposted Tue 13 Dec 16 @ 12:27 pm
GianVJPRO InfinityMember since 2012
Excuse me for delay for answer.
I tried with my configuration (Denon DN-MC6000), but it work without issue at first pressed button, on all 4 deck.
The XML code of the skin to manage the PFL button it's the same on all deck.
Maybe it's a problem with the mapper configuration of you controller.
geposted Thu 22 Dec 16 @ 10:38 am
a fellow dj asked me to add in my "remix" decks to the skin.
so i did. the new skin name will be: GianB 4 Decks v3 Remix.
uploaded and waiting for approval.
to see the remix decks:
1. switch to 4 deck
2. click on browser zoom.
enjoy.
geposted Sat 08 Jul 17 @ 6:18 pm
dj dad said i need to get your approval to update the skin.
please say ok to update the skin to an ultra 99 remix decks.
geposted Tue 11 Jul 17 @ 10:22 pm
Sorry, but I did not understand that it was my authorization ... also because "my" skin is derived from a skin made by DJDad.
It is okay for me.
geposted Wed 12 Jul 17 @ 9:16 am
"GianB 4 Decks v4" coming soon... stay tuned :-)
geposted Thu 31 Aug 17 @ 7:07 am
Changes "GianB 4 Decks v4.0":
- Optimize XML code (removed more than 5000 lines of XML code from previous version)
- Some graphics changes
- Some redesign on decks Layout
- Top Beat Counter a little bigger
- Add setting song's Rate directly on the skin (Stars clickable)
- Replaced "CUE buttons" with "Pad buttons" on small deck (decks under big decks, in a 4 decks configuration)
- Add red button "Loop Record" on all decks
- Renamed all Video Custom Buttons, so now are unique on the skin
- Mini-video on deck a little bit larger
- On 4 Decks Layout, with "Video" on Deck Enabled, add option to view:
* "Custom Button" on Video
* "Loop" on Video
* "Pads" on Video
* "Effect"/"Key" on Video
- On 4 Decks Layout, in Scratch tab:
* Add button to switch from 4 Waves to 2 Waves Scratch (Left/Right)
- On 2 Decks Layout:
* In Scratch tab, the Scratch Waves are little bit larger
* In Master Tab, remove the VU-Meter of Mic Rec and expanded the N° of effects slider from 8 to 10
- Redesign 2 Mini Decks Layout (when in big Browser mode)
* Add Master Button
* Add Deck Number Button
* Add Tap Button
* Add Left/Right Button
* Add Scoring Stars
* Add 8 Pad buttons
* Add FX Selector
* Add Loop Button
* Add Loop Record Button
- Redesign 4 Mini Decks Layout (when in big Browser mode)
* Add Master Button
* Add Scoring Stars
* Add 8 Pad buttons
* Add FX Button
* Add Loop Button
* 4 Mini Decks now respect mixer order
- In SandBox area, the switch view button now manage visualization of Master VU-Meter plus 6 top additional Custom Buttons
- Add options menù:
* "+ 2 Mini Deck" and "+4 Mini Deck" (when in big Browser mode) to manage some object visualization independently from Main decks
* "Hide Top Labels"
- Whenever possible I use the VDJ script syntax to localize words on the skin
Some Options variable name are changed, so maybe necessary to reconfigure the skin options.
If you use only this skin, I suggest you to delete (in VDJ Options) "VDJScriptGlobalVariables" to clear old variables name and reconfigure the skin from scratch.
geposted Thu 14 Sep 17 @ 6:29 am
Hi Gian, can't wait to test this skin.
Is it waiting for approval now ?
geposted Sun 17 Sep 17 @ 9:10 pm
geposted Mon 18 Sep 17 @ 9:40 am
OK. I was searching for the 'V4.0' version but it says 3.7 :)
geposted Mon 18 Sep 17 @ 10:33 am
Hi there,
This has probably been requested before, but is there any chance of providing multiple skin colors beside black? Thanks! :)
geposted Mon 25 Sep 17 @ 6:48 pm
You could DIY (this took under a minute to create).
geposted Mon 25 Sep 17 @ 8:19 pm
Oh great! Thank you!!
geposted Wed 27 Sep 17 @ 8:52 pm
So are you OK with doing this? Let me know if you need any help.
It's also fairly easy to add a menu with a bunch of colour choices, like (e.g.) FRUiT's skin, if you're likely to want to change skin colour regularly. It would take a bit longer than a minute but it's not particularly complex.
geposted Wed 27 Sep 17 @ 9:20 pm
Well, actually I would like to know how to do it for this skin in particular (GianB 4 Decks v3). I did learn how to add custom colors to FRUIT's skin, so if it's the same process here, than I'll give it a shot now and let you know how I make out. Thank you very much groovindj.
geposted Wed 04 Oct 17 @ 6:05 pm
GianVJ wrote :
Discussion about GianB 4 Decks v3
I hope you still on it !! it´s really the best ( for me ) !!!
geposted Sun 19 Nov 17 @ 5:42 pm
Changes "GianB 4 Decks v4.2":
- Fix wrong background of "transparent" buttons over video decks
- Removed Top button "Wave" and moved this function under "Options" Menu
- Removed Top button "Sampler" and moved this function under "Options" Menu
- On "Video" tab, add Right-Click to switch from 3 Videos / 1 Master
- On 4 Decks Layout, in Video Tab, removed "Master" video only button to switch from 3 Videos / 1 Master and moved this function under "Options" Menu
- On 4 Decks Layout, in Master Tab, add 3 Custom Buttons
- Add view of "Last Play / First Seen" on Decks (Clikable)
- Add toggle view on "Year" (on deck): "Year / First Seen"
- In "Options" Menu, "Waves" section, add option to view 2 (L/R) scratch waves in 4 decks Video Tab
- In "Options" Menu, "Hide Components\Deck" section, add option to hide label "Elapsed/Total"
- In "Options" Menu, "Hide Components\Deck" section, add option to hide label "Last Play"
- Add 2 Custom Buttons on Top Bar (at right of "Transaction")
- Add grid on Scratch Waves (switchable by "G" button)
- Add Graphics Equalizer on top Waves zone (switchable by "E" button - require VDJ 2018)
- Add Graphics Equalizer on Master Broadcast monitor (while Broadcast it's Off - require VDJ 2018)
- Some minor graphics changes
geposted Wed 12 Sep 18 @ 8:09 am
Hey Gian,
Does this skin work with latest version VDJ 2020 or just 2018 version ?
Thanks
Harry White
geposted Sun 12 Jan 20 @ 1:11 am
96%
