Discussion about GianB 4 Decks v3
geposted Wed 24 Jun 15 @ 6:12 pm
Long time user and I just wanted to say that I'm loving your skin!! Great work!
geposted Thu 16 Jul 15 @ 7:39 am
In this version I had take the great skin "Swap 4Decks" of DJDad (so major credits it's for him) and adjust it with my needed and add new features.
I'm happy you like it :-)
geposted Fri 17 Jul 15 @ 1:36 am
Hello,
would it be possible to have the scratch-wave only for the selected deck and not for all decks, and if possible the choice of an V-Split?
Regards, Thomas
Regards, Thomas
geposted Thu 23 Jul 15 @ 6:02 am
The scrath wave form option for selected deck it's already in this skin: click on "gray" wave button (the first button of group "Wave Type" on top of form) and on the menù select "Scratch Wave: Selected Deck".
For request for "V-Split" I don't understand what you mean. Can you explain better the request and/or show me an example ?
geposted Thu 23 Jul 15 @ 7:10 am
Thank you very much ...
For the split, maybe you could have a look on the skin of friut ( V8 but by FRUiT) because there you could choose it. That means that you have your wave on the left (deck 1 and 3) and right (deck 2 and 4) side ... hope you understand ;-)
geposted Thu 23 Jul 15 @ 7:37 am
Really great skin! GOOD WORK
Would it be possible to add a Sampler Master Level knob or custom knob close to the sample view?
geposted Thu 23 Jul 15 @ 3:47 pm
Hi, that was not what i mean ... i have seen that you have for the standard wave (left / right). That would be great to have it also for the scratch wave
geposted Fri 24 Jul 15 @ 4:37 am
I'm working on an updated version... stay tuned.
geposted Fri 24 Jul 15 @ 5:13 am
Hi, are there some news ;-)
geposted Tue 04 Aug 15 @ 1:20 am
I'm in final test... with some news ;-)
I hope to upload it for approvation this week.
geposted Tue 04 Aug 15 @ 6:18 am
Ver. 3.1 changes:
- Sampler:
- New central tab Sampler
- Option to Show Sampler on Vertical View
- Option to Show Sampler on Horizontal View
- Separate Save/Recall Wave & Scratch Wave
- Add Zoom buttons options on 2 Decks view
- Waves:
- Scratch Wave Left-Right
- Scratch Wave Left-Right Split
- Little bit higher wave zone
- Reworking Waves layout
- Master Tab:
- Add 4 effects knobs (12 total)
- Add stereo Master Vu-Meter
- Change broadcast layout
- Swap option between Sanbox <-> Pre-Listen
- Right-Click on Pitch Range to down the value
- Wheel options on decks
- Some minor changes
- Sampler:
- Waves:
- Master Tab:
geposted Thu 06 Aug 15 @ 6:50 am
I enjoy your skin. Good work
Did you add a sampler volume control knob or am I blind?
It would be very nice to see the sampler output volume setting somewhere!
geposted Thu 06 Aug 15 @ 10:52 am
The sampler volume slider it's now present in 3 different position:
1) Enable the new central tab "Sampler" (near "Master" tab)
2) and/or enable horizontal view Sampler (using white icon sampler button on top and select appropriate menù)
3) and/or enable vertical view Sampler (using white icon sampler button on top and select appropriate menù)
In all 3 view there's a slider to adjust Master Sampler volume.
geposted Thu 06 Aug 15 @ 11:56 am
Thank you very much! I am blind... :)
geposted Thu 06 Aug 15 @ 1:41 pm
Thank you very much for your work ...
Just one remark :-)
Would it be possible to "switch off" the custom buttoms (if ... like me ... you don´t need them)
Just one remark :-)
geposted Fri 07 Aug 15 @ 6:19 am
hi, me again :-)
would it be possible to have the waves without the "white stripes"
lokke
lokke
geposted Sun 09 Aug 15 @ 11:43 am
DJLokke wrote :
hi, me again :-)
lokke
lokke
I'm working on new version ;-)... maybe implement request as option.
geposted Mon 17 Aug 15 @ 6:56 pm
DJLokke wrote :
hi, me again :-)
lokke
lokke
Hi, any news ;-)
geposted Wed 16 Sep 15 @ 5:58 am
The New version are in final test, but now I'm in holiday; I came back at end of september.
geposted Wed 16 Sep 15 @ 6:47 am
