How do I check library for missing files, I have the the exist=0 script but that is not working, and the only way to catch dead links is when I'm on set and try to play a song then thats when I see it doesn't exist, this is so frustrating.
geposted Mon 31 Aug 15 @ 11:53 pm
Dont worry MediaMonkey to the rescue!!
geposted Tue 01 Sep 15 @ 5:16 pm
Are you saying the current system in VDJ8 does not work ?
That being.. bottom left hand corner browser options radio button --->Database--->Remove missing files from search DB
geposted Tue 01 Sep 15 @ 7:12 pm
I use that.
geposted Tue 01 Sep 15 @ 9:03 pm
Now you wanna have answers....
geposted Tue 01 Sep 15 @ 10:48 pm
A little over 5 hours is not a bad response time lol.
I've been waiting on Peavey support for over a month.
This lot here are close to brilliant when compared to similar forums.
geposted Tue 01 Sep 15 @ 11:02 pm
And No Its doest work, I found a track thats not there ran the remover missing files and the track is still there...so no it doesnt work
geposted Fri 04 Sep 15 @ 12:14 pm
Maybe you should try exists=0
At least, that is working for me.
geposted Fri 04 Sep 15 @ 12:23 pm
If it still shows up that means it's probably added back from a playlist or virtual folder that still has the missing file.
geposted Fri 04 Sep 15 @ 12:51 pm
So its a software bug, ok...well maybe it should be looked at. Cause if its supposed to be removed then it should also be removed from said items....
geposted Fri 04 Sep 15 @ 7:25 pm
