I drag and dropped a song from the Shazam folder into a virtual folder.
I can not find immeditaly how to delete it.
geposted Fri 20 Nov 15 @ 1:39 pm
Try the "delete" button on keyboard ;-)
geposted Fri 20 Nov 15 @ 1:50 pm
I'm glad someone from the staff knows how to delete a file ;-)
FYI a mac has no delete button, you can do it with cmd-backspace and this works. But, as I never use my keyboard, I want to do this with my mouse, but there is only a lookup option, no delete option with this kind of files when you rightclick. Other files have the option 'remove from this virtual folder'
geposted Fri 20 Nov 15 @ 4:03 pm
You only get a lookup option because this is not the actual file.
From the cloud lists and Shazam etc when you attempt to load them they will search Content Unlimited for the track.
You can then cache them and then store them in a playlist etc.
That's why you only have the lookup option.
geposted Fri 20 Nov 15 @ 5:47 pm
I don't understand it completely. In the Shazam folder they all have bleu marks, half of them has also green marks. They even have a calculated bpm.
I can put the green one's in a virtual folder and I can load them directly with drag and drop in the player.
But this has nothing to do with my problem, I can delete it with the keyboard, why not with the menu?
geposted Fri 20 Nov 15 @ 7:07 pm
Which skin are you using?
geposted Fri 20 Nov 15 @ 7:09 pm
Orangejuice.
Ok, I tried with the default skin, and it works. It's the skin.
geposted Fri 20 Nov 15 @ 7:17 pm
but not when you drop it in a virtual folder.
geposted Fri 20 Nov 15 @ 7:20 pm
just want to check this with my skin........but wtf is VDJ 8.1?......never heard before
geposted Fri 20 Nov 15 @ 8:51 pm
first of all, thank you for your skin.
And it has nothing to do with the skin. I was to early with my conclusion.
You misses with VDJ 8.1 sometimes the right-click menu to delete the Shazam-tracks look-up options when you have moved them to another location. It only works with the keyboard, I never use.
geposted Fri 20 Nov 15 @ 9:21 pm
FYI: you did not mention that you are on Mac :-)
geposted Fri 20 Nov 15 @ 9:35 pm
That you took your conclusion before asking, it's nothing to be ashamed about: most of Atomix-staff and developers always forget that there is also something as a Mac ;-)
geposted Fri 20 Nov 15 @ 10:26 pm
djnice :o) wrote :
wtf is VDJ 8.1?
Announcement here http://www.virtualdj.com/forums/205350/General_Discussion/_NEW__VirtualDJ_8_1.html
Right now, only those who have "get beta builds" enabled received the automatic update to 8.1 but it will be available to everyone soon.
geposted Sat 21 Nov 15 @ 10:42 am
Thx, i got it
geposted Sat 21 Nov 15 @ 10:47 am
