action="setting 'RPM' '4 beats'" is nor working
geposted Sat 21 Nov 15 @ 11:49 pm
Seems to be working here (VDJ 8.1 b2582).
I set it to 4 beats and the jog markers (Mixlab VDJ 8 skin) rotate to the same point after one bar.
geposted Sun 22 Nov 15 @ 10:26 am
The setting works if changed from the OPTIONS, but not when the action is used on a custom button (and probably on a skin too).
Reported to Dev Team and will be taken care soon. Thanks for reporting.
geposted Sun 22 Nov 15 @ 10:55 am
...thanks!
geposted Sun 22 Nov 15 @ 1:12 pm
I have found that it was not working yet
setting "keyDetection" broad range
setting "autoCue" skip silence
setting "autoCue" first beat
and probably where there are two words
geposted Sun 22 Nov 15 @ 1:42 pm
if you don't add quotes around them, they will of course be treated as 2 parameters instead of 1
geposted Sun 22 Nov 15 @ 1:55 pm
is ok Adion
Thanks for the clarification because there is no example in
Example: setting 'jogSensitivityScratch' 80%
geposted Mon 23 Nov 15 @ 7:35 am
RELOOP Controller is bestmix4.
All deck managed to set the scratch.
Except for the 1st deck scratch which you can only pause mode. Can you possibly some solution?
geposted Fri 27 Nov 15 @ 12:18 pm
Enable "Vinyl Mode" on deck 1.
Also the thread you are using to post has nothing to do with your issue, so please next time try to use a more appropriate thread or create a new one.
Thank you! :)
Thank you! :)
geposted Fri 27 Nov 15 @ 12:37 pm
so "setting RPM '4 beats'" should work? Not for me.....
geposted Mon 30 Nov 15 @ 2:08 pm
No, setting RPM '4 beats' does not work currently.
What Adion said was for
Where the parameter isn't quoted.
The above scripts DO work if quoted properly! :)
geposted Tue 01 Dec 15 @ 8:44 am
